Sponsored by: CARiD
Brake lines
Old Nov 28, 2023 | 04:19 PM
Performance nut's Avatar
Performance nut
Default Brake lines
I haven't tinkered on C8 brakes yet. Do they benefit from having aftermarket brake lines? This seems more of a custom touch and less of a "I need this to go fast on the track or I'll die".
Not diminishing the product, I have ran these before and had zero issues. But makes me wonder if it was an overkill upgrade.
Old Nov 28, 2023 | 05:08 PM
J5isalive's Avatar
J5isalive
The C8 brakes leave a lot to be desired with how much control the ECU has over the feel and application of the brakes.... i wouldnt run to the store to buy brake lines but I think they helped a little bit, however i didnt install just lines, i installed lines in conjunction with the AP racing front and rear kit.
Old Nov 28, 2023 | 05:13 PM
Performance nut
I'm thinking of keeping the stock calipers and running the AP Racing rotors. Don't see much of a reason to change the lines unless there is good reason for it.
Thank you for answering my question!
To Brake lines
