Sponsored by: CARiD
Frunk Lid
Old Dec 7, 2023 | 02:16 PM
EVL-C8's Avatar
EVL-C8
Default Frunk Lid
Can the Frunk lid be adjusted?
Mine is about an 1/8' high but the rubber stops are all the way in and you push it down
when closed but it springs back up to the stuck high position?
Like the latch needs adjusted lowered?
I just noticed this today the way the sun was hitting it?
Old Dec 7, 2023 | 02:48 PM
Andybump's Avatar
Andybump
Old Dec 7, 2023 | 02:59 PM
EVL-C8's Avatar
EVL-C8
Thanks for the reply.
Mine appears to be lined up correctly as far as gaps on both sides but the front sits a little high?
It has enough free play to push down even with the front bumper but does not stay there?
Does that make more sense?
Old Dec 7, 2023 | 09:10 PM
mortelec's Avatar
mortelec
Pull the frunk trim off and lower the latch.
Old Feb 1, 2026 | 04:46 PM
Dtimmscott's Avatar
Dtimmscott
2nd Gear
I too have the same issue on my Eray . A friend has an Eray as well and his is about 1/8” lower. If some has knowledge, we would be grateful.
Old Feb 2, 2026 | 08:13 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Yep, makes sense. Since you have "plenty of free play but it just does not 'stay there' " the front latch (b) just needs to be lowered.
As @Andybump Pic shows need to loosen front latch bolts and lower. Then tighten bolts! Need to remove the front trim to access.
Old Feb 2, 2026 | 11:39 AM
Mojave Muleskinner's Avatar
Mojave Muleskinner
Default Frunk Lid
My '25 Stingray frunk lid is very temperamental. When opening it with the key fob, it pops up one notch but not fully released. Wait for the beep but still not partially latched. I have to push it down & try again. When closing, it I don't drop it with the right pressure, it won't pull down. Opening & closing takes several attempts before it works as described.
To Frunk Lid
