Sponsored by: CARiD
cel and P0700 code
Old Jan 25, 2024 | 06:19 PM
Silver31581's Avatar
Silver31581
Default cel and P0700 code
I have a 2021 C8 Z51 with nearly 15,000 miles. I got a cel light with some driving issues. Checking the OBD for codes I found a P0700 code #711. It looks like a DCT code. I tried pulling the negative battery cable for 15 seconds. No help. Any ideas?
Old Jan 25, 2024 | 06:26 PM
Red9132's Avatar
Red9132
Cruising
I got the same code today. Mine is a 24 with 1200 miles on it. Just dropped it off at the dealership and they are hoping to look at it tomorrow.
Old Jan 25, 2024 | 06:33 PM
Silver31581
Did you have any driving issues when the cel came on?
Good luck tomorrow!
Old Jan 25, 2024 | 07:01 PM
Red9132's Avatar
Red9132
Cruising
No, it seemed to be driving fine. I wasn’t being too hard on it since the check engine light was on, but it drove and shifted smoothly. How was yours?
Old Jan 25, 2024 | 07:06 PM
Silver31581
It stumbled, lost power occasionally and had jerky shifting at the start. Then everything seemed to smooth out and it ran just fine.
Old Jan 28, 2024 | 10:50 AM
Red9132's Avatar
Red9132
Cruising
Well, it looks like it might have been a false alarm. This is what they came back with.
“RUN SYSTEM CK AND FOUND P0700 STORED IN ECM AS HISTORY CODE. RUN SYSTEM CK AND FOUND U1608 STORED IN TCM FOR "UNKNOWN DTC" STORED AS HISTORY CODE. NO PROBLEM FOUND AT THIS TIME. STORED CODES CLEARD FROM ECM AND TCM AND ROAD TEST, ALL OK.”
They said it might have been a result of a spike in voltage or a drop in voltage. Mine continued to run fine after the light came on. I know yours didn’t, so I hope everything turns out okay for you, as well.
Old Feb 3, 2024 | 12:32 AM
Bob Paris's Avatar
Bob Paris
For my '22 Z51 HTC, at around 300 miles, I had a CEL and "idle creep disabled" message displayed. When I got home I pulled the codes and then did a little online research. Possibly break-in contaminants were interfering with the DCT solenoids. CEL cleared later the same day so I assumed it was a fluke. Since car always drove fine and shifted normally, I did not visit dealer but drove another 7500 miles and then had the first service performed. Car has been flawless since this minor hiccup at 300 miles and I now have around 27,000 pleasure-filled miles on the car.
Old Feb 3, 2024 | 02:05 AM
Silver31581
I'm glad to hear that it didn't repeat. Mine hasn't repeated since it was cleared.
To cel and P0700 code
