Sponsored by: CARiD
Deleting/bypassing Tpms
Old Jan 28, 2024 | 10:02 PM
theseal's Avatar
theseal
Default Deleting/bypassing Tpms
What’s the deal on c8’s? How to ensure that no matter what, never, ever can any module on the car ever take any action based on a Tpms signal or lack thereof? Particularly on z06.
Old Jan 29, 2024 | 01:41 PM
allblackeverything's Avatar
allblackeverything
The car doesn’t care. You just won’t have a tire pressure
Old Jan 29, 2024 | 02:52 PM
theseal's Avatar
theseal
That's what i thought until yesterday. unfortunately that appears to be very wrong in the case of my 24 z06.
Old Jan 29, 2024 | 04:34 PM
allblackeverything
what’s the issue?
Also, why wouldn’t you just add TPMS to your new wheels.
The z06 isn’t tunable yet so you can’t tune it out.
You might be able to throw 4 sensors in your glovebox if you don’t want them on your wheels for whatever reason
Old Jan 29, 2024 | 08:46 PM
mortelec's Avatar
mortelec
Please enlighten us
Old Jan 30, 2024 | 04:23 AM
X25's Avatar
X25
Sr.Random input generator
(1) As far as I know, if you don't have TPMS in any wheel, or if you have it in all wheels, you're OK. If you have it in only some of the wheels, then the car will think you might have a flat/safety issue, and will rein in stability control.
(2) I seem to remember being mentioned here that there is a special combination of buttons you can hit to disable TPMS. If you sarch for it and find it, you can share it here : )
Old Jan 30, 2024 | 08:04 PM
theseal's Avatar
theseal
Originally Posted by mortelec
Please enlighten us
i dont really want to elaborate just yet. Suffice it to say that the car is undriveable and potentially dangerous without tpms in the 2 front wheels, and that was true in any mode or all nannies off. Put the tpms in the other wheels (none of the dealers had any!?) and problem went away.
Old Jan 30, 2024 | 11:27 PM
X25's Avatar
X25
Yep, indeed looks like you had TPMS in only some of the wheels, in which case your car will think you're running on flat tires. You need to either remove all TPMS sensors, or have all 4 of them.
Old Jan 31, 2024 | 07:29 AM
theseal's Avatar
theseal
The dangerous and inexcusable defect is what the car does with that information and what it will do to you if any of the four cheap (probably chinese) $40 sensors ever fails to deliver a signal that makes the bullshit modules happy. So if you turn the wheel, Hal just starts jabbing the front brakes so hard it barks the tires, on and off, repeatedly. The car can be fun and could be so good, but anyone inside a moving one is just hoping it doesnt randomly decide to kill you.
Old Jan 31, 2024 | 07:32 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Since this is the first report like this I've seen on the forum I guess not many here have had their car randomly decide to kill them.
Old Jan 31, 2024 | 08:03 AM
Mark9's Avatar
Mark9
I'd actually take this concern seriously. It's not the first time a safety system had unintended consequences. I'd report the issue to GM. Not sure if it's an issue with your car in particular or a built in issue. There's no way a TPS sensor should initiate braking under any circumstances.
Old Jan 31, 2024 | 01:15 PM
mortelec's Avatar
mortelec
You are probably feeling the ackermann theory. Nothing to do with tpms or having one bad one.
Old Jan 31, 2024 | 06:16 PM
mikegr's Avatar
mikegr
I agree seems like something off. I have heard the car will go into limp mode if a sensor is not detected, again it assumes you had a blow out. Never heard of the car applying brakes.
Old Feb 1, 2024 | 07:38 PM
theseal's Avatar
theseal
lol, no. I have won many championships racing cars, and designed and tested race cars. Not that you need that resume to notice that the car is choosing to repeatedly stab the front brakes (only) so hard it chirps the tires.
Old Feb 1, 2024 | 08:16 PM
X25's Avatar
X25
If you don't have all the sensors, the car thinks you're in dire danger, have at least one flat, and does its best to nullify any move that generates high G (I think limitation was 0.6 G on C6s). I'm sure it feels very weird and unsettling, no doubt on that, but the fix is easy: just use it on all corners, or none.
For note, something similar happens when you also have issues with magnetic shocks. If it loses communication with one of the shocks (which might happen easily when you use simulators), it immediately switches to safety mode, even if you're in the middle of a corner, doing things that scared quite a few owners when it happened. Unlike the case of TPMS, however, removing them all is not a solution as far as I know.
One last time, you can always use the key combination that disables TPMS completely after you start the car. This might be useful if you're only running into this issue during drag runs, track days, etc.
To be honest, I don't blame the car for this behavior at all. They need to make sure the car is safe when TPMS fails, and for those of us using the car for other means, there are already multiple solutions available.
Old Feb 2, 2024 | 12:20 AM
cars's Avatar
cars
you are correct. when 1 sensor doesn't register the car handling is all out of whack. when I have all 4 sensors removed it took about 5 miles before car registered no sensors and handling ok again.
gor this reason i took out all my sensors as i cant have this issue at track. a guy at track told me, you could get a tpms device ans put in learn mode and car will be fine for 15 min or so while it try to learn.
to test your problem. just put tpms in learn mode and your problem should go away until it learned there is a bad sensor
Old Jun 23, 2025 | 03:41 AM
xgaspx's Avatar
xgaspx
Cruising
I'm having a similar problem and it has bricked my brand new (to me) Z06 and ruined my track season. My car has a malfunction where it won't recognize the front left TPMS sensor. On track the car thinks the tire is flat and hits the brakes in every corner. The first time it happened was going up the esses after exiting the pits at Watkins Glen. It is no exaggeration to say it felt like the car was trying to kill me. My car has been in service for 5 weeks while the dealer and a GM engineer try to figure out how to fix this. I know taking out all the TPMS sensors is a workaround but for mid $100K for a car I should be able to use all the safety/convenience features without them ruining my track day or putting my life at risk.
To Deleting/bypassing Tpms
Old Jun 23, 2025 | 09:35 AM
c5racr1's Avatar
c5racr1
Bottom line, you have to have all functioning TPMS or none. If you have 2 installed and 2 not installed, the car will think you have two flats or broken TPMS, and the vehicle will be undrivable. So it's all or none>
Old Jul 2, 2025 | 04:21 PM
Red Mist Rulz's Avatar
Red Mist Rulz
I know that in some cars that won't deal with missing sensors, (even all 4 missing), people have put the sensors in a PVC pipe that's sealed at both ends and has a schraeder valve installed in one end, the pressurize it to the recommended tire pressure and keep it inside the car. That's apparently enough to keep the car happy.
Old Jul 2, 2025 | 04:41 PM
X25's Avatar
X25
I don't think that would work. The sensors need to spin in order to activate (or they stay in sleep mode).
