Sponsored by: CARiD
Deleting/bypassing Tpms
Old Jul 3, 2025 | 05:57 AM
superramvette2's Avatar
superramvette2
Originally Posted by allblackeverything
The car doesn’t care. You just won’t have a tire pressure
It will apply brake pressure to the front calipers in corners if you lose TPMS signal to one of your TPMS sensors under heavy turning and acceleration conditions. You have to be either ALL on or ALL off. At least with non OEM sized wheels and tires. I have tested this on my car and when my rear TPMS went out the car would not allow you disable to stability control system. If ALL are off it will eventually allow you to disable stability control after driving for a bit and not do that. It's a horrible feeling having the car apply brake pressure so I understand what original poster is talking about.
