Turn off Big Brother
There's nothing else inside the passenger side antenna box - just the primary cellular - so nothing else should in theory be affected. According to diagnostics, several satellites are connected to GPS, so that appears to be working fine.
The way the diagrams are drawn (with arrows in both directions) and the above wording from the service manual, I believe the passenger side antenna, being "primary cellular", is for doing two-way communications.
Diagram for secondary implies receiving duties. Which would make sense since "diversity antenna" setups use a pair of antennas to improve *reception*. You would not transmit from a pair of antennas unless you're using interference to target something at a specific location.
The car has lost its ability to transmit tire pressure info since I disconnected the Primary Cellular antenna, and the feature was restored within a minute of reconnecting that antenna. Only the primary appears to be capable of being used for transmitting. So I'm satisfied that OnStar can not receive data from me via cellular.
The car does not have access to any password protected Wifi network. Whether the car would use an open wifi network to upload stored data is unclear, but I believe this is very unlikely given the security issues of connecting ***** nilly to an open network. So I'm comfortable with that until I get it near open wifi to make sure it doesn't connect and use that wifi. Again, seems quite unlikely to just start using wifi without at least asking me. Do we know if it would even send telematics by wifi? I could repeat my tire experiment with a wifi connection active.
I'm feeling pretty confident this problem is solved.
There's nothing else inside the passenger side antenna box - just the primary cellular - so nothing else should in theory be affected. According to diagnostics, several satellites are connected to GPS, so that appears to be working fine. Good. I was concerned that it might shut down everything, not just cell comms.
The way the diagrams are drawn (with arrows in both directions) and the above wording from the service manual, I believe the passenger side antenna, being "primary cellular", is for doing two-way communications. It shows two way comms to the telematics module. See attached.
Diagram for secondary implies receiving duties. Which would make sense since "diversity antenna" setups use a pair of antennas to improve *reception*. You would not transmit from a pair of antennas unless you're using interference to target something at a specific location. Interesting point. I might have designed it to transmit via the antenna that also received the strongest signal. But I do not know what they did, and can find no evidence of how the secondary path is used.
The car has lost its ability to transmit tire pressure info since I disconnected the Primary Cellular antenna, and the feature was restored within a minute of reconnecting that antenna. Only the primary appears to be capable of being used for transmitting. So I'm satisfied that OnStar can not receive data from me via cellular. I think so. I'm still interested in what happens when back together and you drive around a bit.
The car does not have access to any password protected Wifi network. Whether the car would use an open wifi network to upload stored data is unclear, but I believe this is very unlikely given the security issues of connecting ***** nilly to an open network. So I'm comfortable with that until I get it near open wifi to make sure it doesn't connect and use that wifi. Again, seems quite unlikely to just start using wifi without at least asking me. Do we know if it would even send telematics by wifi? I could repeat my tire experiment with a wifi connection active. Yes, I think it would send the alert via WiFi if connected. I wonder if it will also notify OnStar about the perceived issue with the antenna and send a diagnostic about that. I agree that it very likely will not connect to any networks unless you ask it to do so via the menu in the car.
I'm feeling pretty confident this problem is solved. I think so. I think there is a very very small chance that the secondary path might somehow wake up and transmit something. I just wish I could find more info about it.
The text is similar. There are configurations without Nav (IOT upgraded, IOS standard infotainment system) and I think neither. And configurations without OnStar (UE1).
There are very long descriptions of the operation, and the specific configuration is only mentioned at the start of the paragraph. So, you can be reading along and then discover non of it applies. The diganostics sometimes indicate the applicable configuration at the top, but sometimes have the differences buried in the procedure.
When I post info from the manual, I try to select the applicable configuration for the US market with OnStar.
Transmitting from more than one antenna at a time (on purpose) would be for beam steering... I can guarantee there is no beam forming in the OnStar system.
https://youtu.be/xqkTd6IZVj4
Couple of questions about disconnecting the antenna. Will Apple carplay/ radio/ Bluetooth for music & phone be affected? I see you lost tire notifications but can you still see the tire pressure & heat? Anything else of note that might be affected?
Is it like credit reporting agencies, you can get your info, if you share things like you SS, birthday etc. I'm not excited about going to a strange web site and supply data to them in order to get what they might have already. I could make matters worse.
The only tire notication lost was the one sent via the cellular notification. This will not affect on board tire pressure monitoring and alerts.
If the goal is to shut down the data sharing, however, I think there may (repeat may) be an issue since WiFi still works. If the WiFi connects to an external internet enabled network, such as your local WiFi in your garage, it might (repeat might) send the same data to OnStar that it would have via the cell connection. We know that the WiFi connection will support receiving of OTAs, will support download of apps, and while connected it will proved data needed to support those apps. For example if you have a pandora app in the infotainment system, but no data plan (or no cell connection) , but you connect to the external network in your garage, it will receive the necessary data and play music. I think that the WiFi cannot connect to a network without being requested to do so via the car menu - if I am right - then one could prevent that connection. The phone can also connect to the car "hotspot" as a connected device - and that is how it connects when it supports wireless carplay (at least prior to 2024). I can see all this on my 2021 menus. However, when its connected to support wireless carplay, I think (guessing again) that does not see that as an internet connected network (even though the phone is connected to the internet) and so it will probably not try to send data to OnStar when connected that way. Lotta "if I am right" s in this missive.
the only way any responsible american would ever own any car is with all of the car's ability to send or receive any data or commands to or from anyone, anywhere, any time, completely, permanently and totally disabled.
Anything else means you dont actually own the vehicle, and are nothing more than a potential victim of all kinds of misconduct.
Since all the car manufacturers and governments are making responsible american ownership extremely difficult, i really appreciate the info on this thread.
While my c8 z is mechanically interesting in some respects, and does a lot of pretty impressive things for a factory car, it is also just a disposable short term asset due to these defects. Once my real car is finished, I'll be selling it. or if i just fall in love with it, the only way i would own it is to rewire the entire car properly and throw all that **** out.
The solutions being discussed here are a very welcome middle ground.
Similar test, only now use the phone in hotspot mode and connect it as a network. Again, I'm betting the message appears right away. I think you have to start each test, with correct inflation and let air out, it may trigger on a change.
Finally, once more, only now connect the phone to support car play. I'm betting it does not transmit the alert.
I also doubt GM would have made it to transmit that data though any other method. So far this looks like an easy (reversible) way to stop it.
