Sponsored by: CARiD
Track vs Street Alignment
Old Mar 1, 2024 | 09:27 PM
Mark9's Avatar
Mark9
Default Track vs Street Alignment
Looking to get the car on the track this upcoming season. The majority of the miles will be on the street. Is there a set of specs that are a compromise between those settings that will do ok on the track and not cause too much crazy wear on the street?
Old Mar 1, 2024 | 09:54 PM
mikegr's Avatar
mikegr
I have 5000 miles on my car so far with several track days and dont have crazy wear. If you run front toe at 0, I dont seem to see excessive wear from the camber only. I run full track alignment all the time
Old Mar 2, 2024 | 01:14 AM
X25's Avatar
X25
Sr.Random input generator
+100, keep front toe at zero, and rear close to it (0.05 degrees toe in), and it should limit the tire wear, and might help with increasing your trap speeds, too, with lowered scrubbing.
I also drive at full track alignment all the time...
Old Mar 2, 2024 | 07:42 AM
jwt1603's Avatar
jwt1603
Trck all the time for me too.
Old Mar 2, 2024 | 02:43 PM
Ruouthere's Avatar
Ruouthere
Semi high jacking this tread....the 2023 Sting Rays, what did/does the factory set the alignment to, Street or Track? I assume street but....thanks all.
Old Mar 2, 2024 | 02:52 PM
Mark9's Avatar
Mark9
Street….
To Track vs Street Alignment
