Sponsored by: CARiD
Need battery maintainer advice
Old Mar 16, 2024 | 12:50 PM
Kbmwgt's Avatar
Kbmwgt
Default Need battery maintainer advice
My C8 is on order so I'm shopping for the extras.
I would like a battery maintainer and in my readings here I settled on the NOCO GENIUS10. But it does NOT have a 12v cigarette lighter adapter (not sure of the term used now).
The C8 does have one of these in the frunk for such usage correct?
Should I look for a different charger? I'd rather not have to 'get to' the battery every time I want to hook it up or unhook it.
Advice?
Old Mar 16, 2024 | 01:41 PM
Ames's Avatar
Ames
Get a CTEK.
Old Mar 16, 2024 | 01:54 PM
Mark9's Avatar
Mark9
Battery Tender Jr. Cheap and it works just fine. I modified the end to be able to plug into the charge port in the frunk. I see no need to spend $100 on a tender. Have used mine for years on other cars and two winter seasons on the C8 without any issue or concern.
Old Mar 16, 2024 | 03:28 PM
Andybump's Avatar
Andybump
Advice?
Buy one with the cigarette lighter style plug included, or get the adapter separately, as you wish. There are plenty out there. Attached is the one I use. Note that they all will have a replaceable fuse in the plug.
Old Mar 16, 2024 | 04:02 PM
Kbmwgt's Avatar
Kbmwgt
Originally Posted by Ames
Get a CTEK.
Which CTEK? Model?
Old Mar 16, 2024 | 04:11 PM
Kbmwgt's Avatar
Kbmwgt
OK...looking at CTEK and Battery Tender Jr.
Next question can either or both of these be used with a extension cord? Distance from outlet to car is too great to just plug maintainer in wall and have the wire reach the frunk.
Old Mar 16, 2024 | 04:22 PM
Andybump's Avatar
Andybump
Is this going to be outside?
Old Mar 16, 2024 | 04:26 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
You're in luck................BatteryMinder is on sale. If you were in aviation you would know that BatteryMinder is the ONLY way to go. The same page has a cigar lighter plug-in. BatteryMinder INVENTED de-sulphanization.
https://www.northerntool.com/search?s=batteryminder
Old Mar 16, 2024 | 04:33 PM
Mark9's Avatar
Mark9
I use an extension cord. No issues
Old Mar 16, 2024 | 07:28 PM
wrecker3's Avatar
wrecker3
I started using Deltran Battery Tenders back in 1984 and never had a problem !!
Old Mar 17, 2024 | 08:05 AM
killian96ss's Avatar
killian96ss
Just get the NOCO adapter from Amazon, probably around $18 or order directly from NOCO.
Old Mar 17, 2024 | 10:37 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
What @killian96ss said. I have a NOCO Genius with the adapter - works great
To Need battery maintainer advice
