I posted this a few days ago, and saw a thread of about 51 responses, owners all having the same issues, but no solution other than turning the radio up!
Does anyone know of a real solution?
posting
" have 2024 HTC and hear the same noise when V8 drops to the v4, Is there a solution to get rid of this? I hate to bring it in for them to tell me they see nothing.
The only way I know it goes from V8 to V4 is by the light on the dash. I never feel it or hear it. Mine must be one of the few that GM actually built right. I never hear injectors ticking either. Both issues would bother me to the point of selling the car.
AFM is part of the system. Your manual discusses which modes it doesn't work, Active Fuel Management column on the chart page 201. If you don't like it, follow the chart on how to disable it.
i hear the same click noise when the AFM valves and lifters engage. there is nothing that can be done about the noise. just like the ticking noise of the injectors, all you can do is mask the sound by turning up the radio.
As mentioned above, if you drive in manual mode or have the engine settings to track mode, it disables AFM so you will be in V8 mode the whole time
If you're dealing with noise and vibration because of the cylinder deactivation feature, there's a gadget called an AFM disabler that can help. It plugs into the OBD-II port and turns off the feature, keeping your engine running on all eight cylinders all the time. This should stop the noise and vibration when the engine switches to V4 mode, but keep in mind, you'll probably see worse fuel efficiency. Plus, it could void your warranty or cause problems with emissions, depending on where you live.
Another option is custom engine tuning. Some shops can tweak the engine's settings to turn off the AFM system and fine-tune other performance aspects. This can be a more seamless solution, but it comes with similar risks to the warranty and emissions. It's definitely worth considering if you want a smoother engine, but make sure you're aware of the possible downsides.
Not available for the C8. As mentioned prior, Manual mode or Z mode. Or a very expensive ECM change.
1. I can hear it. I can feel it. It does not bother me generally, but in leisurely cruises on rural roads, it does enter and exit V4 mode frequently and then I find it annoying. So, I go to manual shift mode for that.
2. Ways to disable that come with the car - a) manual shift mode, in any Drive Mode. b) set engine/shift to Track in Z mode. c) use Track Driver Mode.
3. Disabling device - there is no device that can be plugged in to disable it. (unlike previous models).
Is this a HTC thing? I can't hear ticking or the V8/V4 in any way but I have a coupe.
Ticking is the one thing I do not hear. I have an HTC.
I can detect the V4 mode, with the top up or down, but much more noticeable with the top down. I suspect its because, besides sound of the actuators or the subtle change in feeling, there is change in the exhaust note - because all the muffler valves close in V4 mode.
Same for me. If it were not for the light on the dash and the great mileage I would never know when it went in and out of V4. I also never hear the injectors. I don't hear a lot of things as well as I used to.
posting
Saw this video the other day about changing the engine oil. Guy claimed that after the oil change was completed properly, the V8 to V4 noise disappeared. There's seems to be a fair amount of shops that don't know how to properly changed oil.
After driving my 2022 HTC Z51 for 3000 miles, I started hearing a loud ‘clunk’ when the C8 switched to V4 mode (the AFM valves). I thought about taking it into Chevy under warranty, but I was looking at aftermarket exhausts anyways. Driving with the top down was obviously louder. I was frustrated, so I installed an aftermarket Lemans Edition track exhaust with no AFM or exhaust valves. No more ‘clunk’ sound over to V4, but I don’t like the deeper V4 tone when it switches. Drive in manual except when on the interstate to save gas. Made the car 2x as fun to drive and no more ‘clunk’!
