Sponsored by: CARiD
DCT Changes / Updates
Old May 3, 2024 | 07:39 PM
green2000's Avatar
green2000
Default DCT Changes / Updates
My 2020 Stingray was built in September 2000. The DCT was replaced in September 2023. The new part number is 24047269. I see that it replaces 24045885 & 24047778.
Is there any way that I can find what the differences are between these transmissions? I'd like to know this for future recalls or service.
Old May 4, 2024 | 06:43 PM
kromdom's Avatar
kromdom
Dealer or GM??
Old May 4, 2024 | 10:30 PM
green2000's Avatar
green2000
Originally Posted by kromdom
Dealer or GM??
I will follow up with the dealer but don't have a GM contact.
Old May 4, 2024 | 10:32 PM
kromdom's Avatar
kromdom
found via Google. Best of luck.
https://general-motors.pissedconsume...r-service.html
Old May 5, 2024 | 10:00 AM
green2000's Avatar
green2000
I will give them a call.
Old May 8, 2024 | 07:43 PM
green2000's Avatar
green2000
I caled Chevrolet and provided all of my information including VIN. I was on hold for 6 minutes and then wsa disconnected.
They sent me a survey and I rated them very low and explained what i need. I expect someone will be getting back with me soon.
I will probably call again in a day or so.
Old May 9, 2024 | 12:05 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Don't hold your breath waiting for them to get back with you. Hope you have better luck if you call again.
Old May 10, 2024 | 09:21 AM
green2000's Avatar
green2000
The correct number to call is 800-222-1020 but it may transfer you somewhere else depending on what the computer wants to do. Make sure that you are really in customer service.
I have my answer or at least a reasonable one. The replaced transmission only fits 2020 Corvettes. I have to assume that it has only minor differences from the superceded parts. I had expected that thr replaced transmission might have been updated to correct known problems. Evidently that must not be so. This probably minimizes any furthur service concerns.
My warranty is not extended and I have to pay for the initial 7500 mile transmission filter replacement.
Old May 10, 2024 | 11:06 AM
Andybump's Avatar
Andybump
Sounds right. And based on recent comments during the bash, to once again confirm the mileage for the second filter change - it is at 22,500 miles and then every 22,500 miles after. I have attached the statement from the bash. So the second change is intended to be 15000 miles from the first one. This is consistent with answers the same folks have given in the past."Corvette Today – 212 - from the recent bash:
"Question by Andybump about how the DCT Filter Life Monitor Works, is the second change at 22,500 miles, or is it 22,500 after the first change?:
Josh Holder: So, the second change is at 22,500 miles, then 22,500 miles after that."
Old May 10, 2024 | 11:25 AM
green2000's Avatar
green2000
That is for those with their original transmission. All of my service is moved forward 7500 miles.
Old May 10, 2024 | 11:45 AM
Andybump's Avatar
Andybump
That is for those with their original transmission. All of my service is moved up 7500 miles.
That was intended to be my point. You need to have it replaced 7500 miles from whatever you had when its replaced (which you said), and then15000 after that and then 22,500 miles after that.
It was just meant as a reminder that the second change interval is also shorter for a new transmission.
To DCT Changes / Updates
