Sponsored by: CARiD
PSA: Ultimate9 Throttle Controller - The fix
Old May 13, 2024 | 01:11 PM
SorbsC8's Avatar
SorbsC8
2nd Gear
Default PSA: Ultimate9 Throttle Controller - The fix
PSA: After 500 mile break-in, my gas pedal felt stiff, like there was a brick under it. The solution is Ultimate9 Throttle Controller. It only takes 15 minutes to install, and after setting the sensitivity to level 5, the throttle response is so much better. Night and day difference. If you want to make your throttle-by-wire vehicle more responsive, I highly recommend the Ultimate9 Throttle Controller. It's an easy fix that can really enhance pedal feel without major modifications.
If interested the install is simple:
Tools needed: a 10mm socket to remove the gas pedal (this simplifies the wire connection to the pedal)
1. Remove rubber grommet on the gas pedal and remove 10mm bolt
2. Slide gas pedal forward toward seat
3. Push RED locking clip "up" and fiddle with it until the pedal connector disconnects. I found that pushing on the black retainer under the red tab releases the connector easier
4. Plug in the Ultimate9 connector
5. Run the wires under the carpet and place the controller where you can see it to make easy adjustments on the fly
That's it.
Similar connector with the red tab
Old May 13, 2024 | 01:33 PM
Dan Hintz's Avatar
Dan Hintz
Probably because that's how the plug was designed The red clip prevents the tab from being pushed down, which is the actual release mechanism.
Old May 15, 2024 | 08:11 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Does essentially the same thing as the Soler throttle controller, which may folks here have installed.
Just curious: does this let you control it with your cell phone, via Bluetooth, like the Soler does?
Old May 15, 2024 | 08:52 PM
winders's Avatar
winders
That's it.
This, from the web site, is worrisome:
Automatic Mode: Sets the EVC apart from other throttle controllers. A.C. automatically chooses an Ultimate Mode throttle response based on the amount of pedal pressure. Great for long drives or when towing over varying terrains.
I was not aware that he C8 pedal measured pedal pressure! Hint: It doesn't. Too funny....
To PSA: Ultimate9 Throttle Controller - The fix
