Sponsored by: CARiD
Battery quick disconnect?
Old Jul 28, 2024 | 12:36 PM
Scott_Wisconsin's Avatar
Scott_Wisconsin
Default Battery quick disconnect?
Anyone know of a quick disconnect for these cars? Seems a hassle to always remove the panel / side pieces every time, especially for those who track and need to replace pads all the time.
Old Jul 28, 2024 | 03:06 PM
meesterover's Avatar
meesterover
https://www.crutchfield.com/p_120CB2...aker-200A.html
ChampRacerJ's Avatar
ChampRacerJ
Agree, I leave the 2 side pieces of trim off. And only have to remove the large center section. But agree its a pain...
I admit that I've spread the pads and with in two seconds swapped out one pad at a time without disconnecting the battery.
Old Jul 28, 2024 | 05:57 PM
Scott_Wisconsin
Do you use the remove caliper method, or leave caliper on method?
Old Jul 28, 2024 | 06:49 PM
m2man's Avatar
m2man
Just lookup “Remote Battery Disconnect Switch” on Amazon. They are pretty cheap. Just wire to the ground lead.
Old Jul 28, 2024 | 06:57 PM
Scott_Wisconsin
Well I was sort of looking for what anyone has done to prevent removal of the panels, a battery disconnect is easy, having to remove the panels all the time is a pain...
Old Jul 28, 2024 | 07:03 PM
m2man's Avatar
m2man
It literally has a remote control. So you click a button, then the battery is disconnected… you have to remove the panels only to install it.
Old Jul 28, 2024 | 07:04 PM
Scott_Wisconsin
Oh, OK, awesome!
ChampRacerJ
I leave the caliper in place.
I remove the cross pin and all 4 pad bolts.
expand the pads (compressing the caliper pistons).
At this point if the car goes into brake test mode, no harm would be done.
I remove the old pad and slide in the replacement. about as fast as I can say or type this sentence.
That is the only time I'm at risk for that second or 2.
Old Jul 28, 2024 | 07:05 PM
Scott_Wisconsin
OK, great!
Old Jul 28, 2024 | 11:45 PM
A10Beav's Avatar
A10Beav
I just ordered a Joes Racing disconnect switch. I’ll drill a hole in the plastic panel for the switch to come through.
Amazon Amazon
Old Jul 29, 2024 | 07:17 AM
mikegr's Avatar
mikegr
I tend to do the same thing, line everything up with new pad in hand and take old one out, maybe a second where there isnt a pad in front of the piston. I also ensure I dont have my keys on me but I got lazy disconnecting battery every time.
Old Jul 29, 2024 | 10:35 AM
2001f4s's Avatar
2001f4s
I use these on my old cars. Work great:
https://www.amazon.com/RIEIEK-Battery-Vibration-Universal-Disconnect/dp/B0CDWKPLCB/ref=sr_1_3_pp?crid=11MDSHD3JG4LK&dib=eyJ2IjoiMSJ9.Vn8g_1UhutfLxRidFc4nf4LbUs4hmFd8AWepxF78nVJ20IEQDPVzU0Pw7v9rz4Ljcf_olwv6fojojN7GcXjvuzBDviuYcgt6TAWVkpKrHZs8XegTbqxMAteYmkUOMsQ2dzeec3krc0RN7D9o-NBk1SM0cc6SMsikfzEGerjJooJdq2LnsfHc3mn4jN_puznbwmTevyxv_uwJZwvrQaHmdihxuif4-hf2mP-fOfYRMNk.DfemHlHS_JJU1MAz5K9V6ZZRtGAqcZ62-1o30Z97wa4&dib_tag=se&keywords=remote+control+battery+disconnect+switch&qid=1722263612&sprefix=remote+control+battery+disconnect%2Caps%2C234&sr=8-3 https://www.amazon.com/RIEIEK-Battery-Vibration-Universal-Disconnect/dp/B0CDWKPLCB/ref=sr_1_3_pp?crid=11MDSHD3JG4LK&dib=eyJ2IjoiMSJ9.Vn8g_1UhutfLxRidFc4nf4LbUs4hmFd8AWepxF78nVJ20IEQDPVzU0Pw7v9rz4Ljcf_olwv6fojojN7GcXjvuzBDviuYcgt6TAWVkpKrHZs8XegTbqxMAteYmkUOMsQ2dzeec3krc0RN7D9o-NBk1SM0cc6SMsikfzEGerjJooJdq2LnsfHc3mn4jN_puznbwmTevyxv_uwJZwvrQaHmdihxuif4-hf2mP-fOfYRMNk.DfemHlHS_JJU1MAz5K9V6ZZRtGAqcZ62-1o30Z97wa4&dib_tag=se&keywords=remote+control+battery+disconnect+switch&qid=1722263612&sprefix=remote+control+battery+disconnect%2Caps%2C234&sr=8-3
To Battery quick disconnect?
