Sponsored by: CARiD
Wheel Stud Cross Threaded/Stripped
Old Aug 11, 2024 | 07:15 PM
frogman84605's Avatar
frogman84605
Cruising
Default Wheel Stud Cross Threaded/Stripped
Hey all,
Went to replace my C8 brake pads today and that part went great, but unfortunately when removing the rear passenger wheel I had a hell of a time removing a lug and as expected, turns out the there was cross threading and the wheel stud is about 50% stripped.
It’s a real shame since I’ve never taken the wheel off myself on this C8 - only the dealership. How big of a PITA will be to be replace the stud? Rear.
Not sure how to best approach the dealer pointing a finger saying they did this and need to fix for free.
Old Aug 11, 2024 | 07:43 PM
Kracka's Avatar
Kracka
Discount Tire typically does it for free, or cheap, it's unfortunately fairly common. Pound it out with a sledge then suck a new one through with an impact.
Old Aug 11, 2024 | 09:46 PM
Wadejesu's Avatar
Wadejesu
Amazon.com: 22800 Wheel Stud Installer, Durable Heavy Duty Wheel Stud Tool Compatible with Most All Automotive Wheels and Light-Duty Truck : Automotive Amazon.com: 22800 Wheel Stud Installer, Durable Heavy Duty Wheel Stud Tool Compatible with Most All Automotive Wheels and Light-Duty Truck : Automotive
Old Aug 22, 2024 | 07:45 PM
wrecker3's Avatar
wrecker3
I got a DYE from Amzon
Amazon Amazon
Old Aug 24, 2024 | 02:22 AM
X25's Avatar
X25
Sr.Random input generator
My 2 cents:
I always use forged aluminum lug nuts for this very reason. When a mistake is made, the weaker lugs get damaged instead of your lug nuts. One been using cars at the track for more than a decade, and I've never damaged a lug, even though I've damaged quitea few lug nuts due to rushing, using wrong tools, etc...
Old Aug 24, 2024 | 04:04 PM
Dante Inferno's Avatar
Dante Inferno
Cruising
@X25 specially what lug nuts do you recommend?
These???
https://www.bonoss.com/product/bonos...lazer-and-more
Old Aug 24, 2024 | 04:41 PM
X25's Avatar
X25
These???
For my former cars, I've always used Gorilla Nuts (California brand), but for C8, I couldn't find any light, forged aluminum offering from them.
Yes, I've been using Bonoss, and have been pretty happy with them. I usually get extra, and put a lug nut to the glove box as a backup, but I'm yet to strip anything. As a bonus, they're also very light.
I get the dimpled ones, and I also get them in silver, so they'd not look ugly after using impact gun which eventually scratches their paint. Since I change tires a lot, this becomes important : )
https://www.bonoss.com/product/bonos...-sr-mr-lr-2018
Old Aug 25, 2024 | 11:59 AM
Drew888's Avatar
Drew888
Ideally the stud should be replaced with a press or tapped in with a hammer. If you drive it in with a nut you’re limited to 150ftlb of torque.
I have used aluminum lug nuts before on track applications. The forged lug concept is a bit misleading. Some are completely forged to shape with cold formed not cut threads. The later is more important. Can be a machined geometry with a cold formed thread. I’m not a fan for street use because they do wear out relatively quickly and are not the easiest component to inspect. Also aluminum does not have an infinite fatigue life so it’s not if, it’s when they will fail. When the the coatings wear it results in aluminum bearing on aluminum which causes galling. Never use any lubricant on wheel studs. This is the number cause for the type damage that has occurred in your situation.
Old Aug 25, 2024 | 12:03 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I bought one of these a couple years ago. It works ridiculously well. Way easier than pounding or pressing.
Old Aug 25, 2024 | 12:18 PM
Drew888's Avatar
Drew888
These are limited to the maximum tensile load of the stud. If it is exceeded the stud will permanently elongate and will be damaged. Many times the damage is not visible. There is a reason studs are supposed to be installed from behind.
If the shoulder knurling on the replacement stud matches the original sometimes it requires a lower force to install and this type may work. Still not recommended. Even studs made by the same manufacturer can have enough of a difference in shoulder dims to require too much force to be pulled in.
Old Aug 25, 2024 | 07:02 PM
Mr. Black's Avatar
Mr. Black
I'm not disputing what you are saying at all. It is accurate.
That being said, have you ever personally used one of those ball bearing install tools? The amount of force on the threads is dramatically reduced by eliminating the friction of pressing against a stack of washers or a spacer.
Many of us also have enough experience to know when too much force is being applied and to take a step back.
Old Aug 25, 2024 | 07:30 PM
Drew888's Avatar
Drew888
I have used similar tools. The bearing does nothing for the axial load. I’m an engineer and I run a company that develops and manufactures threads. My first job when I was just out of high school was as a tire installer for sears. I have seen it all.
Old Aug 25, 2024 | 07:41 PM
Mr. Black's Avatar
Mr. Black
lol mechanics hate hearing from engineers. Just sayin!
Old Aug 25, 2024 | 09:37 PM
Drew888's Avatar
Drew888
I was a professional mechanic before I was an engineer. I had to work my way through school. Many of my friends that still work at dealers call me when they’re in trouble.
Old Aug 25, 2024 | 09:44 PM
Mr. Black's Avatar
Mr. Black
Most engineers have NO sense of humor whatsoever.
Old Aug 26, 2024 | 12:32 PM
Drew888's Avatar
Drew888
Absolutely a stereo type. I knew you were joking, just wanted to inform those on this thread that I have had a tremendous amount of hands-on experience working on cars and motorcycles for a living. I deal with many engineers daily that have no practical experience they know the theory and not the application. Many don't even know the theory that well.
Old Jan 14, 2025 | 03:23 PM
Car54's Avatar
Car54
So Frogman, did you get the stud replaced and how much did it cost? You will understand my question when you see the post I am fixing to start.
To Wheel Stud Cross Threaded/Stripped
