Sponsored by: CARiD
Rear Axle System Off message
Old Aug 13, 2024 | 12:00 PM
MikeyBFSU's Avatar
MikeyBFSU
Navigator
Default Rear Axle System Off message
I have a 2022 Z51. Got "Rear Axle System Off" message for 3 days last week then engine light came on. Were no issues with any slipping or anything that felt funky. Read some other owners' experiences here on the forum.
Took it to dealership. They contacted GM Technical Assistance Center. They said replace the transmission. I'm under warranty so no argument from me.
Old Aug 13, 2024 | 02:39 PM
Gary barnes 1098's Avatar
Gary barnes 1098
I’m surprised they didn’t atleast try and clear code first?
how many miles you got on her?
Old Aug 13, 2024 | 02:49 PM
Andybump's Avatar
Andybump
GM won't replace a transmission unless the appropriate diagnostics called for by the code have been attempted. So, yeah, I'm thinking the dealer did go through the appropriate diagnostic procedure. Some of the procedures are shorter than others - and get to the "replace the transmission" in less steps than some others. What were the codes?
Old Aug 13, 2024 | 02:59 PM
MikeyBFSU's Avatar
MikeyBFSU
Navigator
They had it 3 days so assume other remedies were attempted...
Old Aug 13, 2024 | 03:27 PM
MikeyBFSU's Avatar
MikeyBFSU
Navigator
Old Aug 13, 2024 | 03:30 PM
MikeyBFSU's Avatar
MikeyBFSU
Navigator
dont have the code info
Old Aug 13, 2024 | 04:05 PM
Joe C5 C2's Avatar
Joe C5 C2
The diagnostic procedures will be listed with the three failures that are required before warranty replacement on the invoice you will get when you pick the car up after trans replacement. I just went through this last week when they replaced my valve body. They will include all parts needed to complete job and thankfully with $0 behind each. Hang in there, it will be fine.
Old Aug 13, 2024 | 05:00 PM
MikeyBFSU's Avatar
MikeyBFSU
Navigator
Hey Thanks for the info, under warranty, all good!
Old Oct 1, 2024 | 03:31 PM
TRI-JAB's Avatar
TRI-JAB
Cruising
Did the dealer replace the transmission? I literally was on my way from the DMV completing the registration on my "New to Me" 2020 Stingray and I go the same message "Rear Axle System Off" and the check engine light came on.
I stopped at my local Chevrolet dealership on the way home. They have me set up for an appointment at 0730 tomorrow. Luckily I have the CarGuru warranty.
To Rear Axle System Off message
