Sponsored by: CARiD
HVAC Issues
Old Aug 14, 2024 | 09:49 AM
Whoad_way_down's Avatar
Whoad_way_down
Default HVAC Issues
We purchased a 2021 C8 last week and now have gone on our first road trip. The HVAC would run cold as expected but about 30 to 45 minutes into the trip the temp would start to climb slowly until it is starting to run low. Anyone have an idea as to what to do besides take it to a dealer on the road and spend a ton of money? I have a Bumber to Bumper warranty but just hate turning loose of the deductable a week into owning the car and have a chance of being stuck without my car for days 500 miles from home.
Old Aug 14, 2024 | 10:15 AM
Pktrusty's Avatar
Pktrusty
I dont understand what is wrong. You say the temperature starts to climb until it is too low?
Old Aug 14, 2024 | 10:21 AM
Whoad_way_down
No...It starts out like expected...cold. Then after about 35....45 mins on road the air from the vents starts to warm. Thanks for the courtesy of your reply.
Old Aug 14, 2024 | 10:30 AM
Pktrusty's Avatar
Pktrusty
Just a FYI, Chevy put the ports in the worst place in the world. They are behind the fuse box and motor on the passenger side. I had an issue with mine after some work I did and I didnt have a error on my dash. I plugged in my scanner and found the problem. Short of putting a gage on it and seeing what your pressures are at, you are pissing into the wind without a scanner. There is a variable flow valve on the underside of the compressor that is held in with a snap ring and can be replaced when evacuated. That ended up being my issue but I dont know that it regularly fails. So first, check pressures, then scan and go from there.
Old Aug 14, 2024 | 10:35 AM
Whoad_way_down
Thank you very much and yep...I know Chevy is going to have to wade in. I just hate dealing with this for tne next 18 days of vacation travel.
Frank
Old Aug 14, 2024 | 10:39 AM
Pktrusty's Avatar
Pktrusty
Just a heads up. If this is covered under warranty, make sure they change the filter if they have to break the system open.
Whoad_way_down
Thanks for your advice. Will follow it as well.
Old Aug 14, 2024 | 11:18 AM
Maxpowers's Avatar
Maxpowers
Is this better suited for the C8 section. Hope you get it sorted out.
Old Aug 14, 2024 | 11:54 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Moved to C8 Tech....if you take it to a dealer good luck with having it diagnosed correctly...they will just change a bunch of parts...hope your pockets are DEEP !!!
Old Aug 14, 2024 | 02:58 PM
3sACROWD's Avatar
3sACROWD
As the temperature of the cabin reaches the set point, the fan speed reduces and the temp of the air being blown will change. If you lower the temp setting, does the air get cooler again? It might be running as intended. If you want the fan speed to remain constant, adjust the fan speed manually. Just a thought...
Old Aug 14, 2024 | 03:22 PM
Whoad_way_down
Luckily we bought a high dollar bumper to bumper, all inclusive Warranty. If I take it to any other Chev dealer I have to pay a duductable...and yep...I am cheap so will have to wait till I get back home in the middle of September. Thanks for the reply.
Old Aug 14, 2024 | 03:23 PM
Whoad_way_down
Thanks, The fan speed is not the issue. The temp of the air coming out of the vent has been rising. I so appreciate your reply.
Old Aug 14, 2024 | 04:37 PM
Andybump's Avatar
Andybump
I had a compressor lock up on a different vehicle while on a very long trip, miles from home. I just drove with windows down. If the AC isnt working there is a chance that the system is low on refrigerant and lubricant. So, potentially, it could lock up, like mine did. Fortunately, in the case of the C8 it looks like it is a dedicated drive belt - so even if the compressor were to lock up and damage the belt, that belt does not appear to drive any other critical elements. Short of going to the dealer, I do no know of anything else you can do other than deal with the heat.
To HVAC Issues
