Sponsored by: CARiD
2020 C8 Corvette
Old Sep 6, 2024 | 09:32 PM
Ferdinand.muniz's Avatar
Ferdinand.muniz
1st Gear
Default 2020 C8 Corvette
Hello my name is Ferdinand Muniz and I have a 2020 Z51 3LT C8 Corvette. I'm about to replace the transmission fluid and both filters (internal & external). I got a copy from GM Service information sheet that stated that the torque for the transmission bolts is 35 lbs the first pass then 93 lbs. I find that the recommended torque is to high do to the thickness of the bolts and material. Does anybody know the right torque for the transmission bolts? My phone number is (580)351-7218 If you would like please give a call. Thank you
Old Sep 6, 2024 | 10:06 PM
Moved to C8 Tech for some assistance.
kkupec02's Avatar
kkupec02
Welcome
Old Sep 6, 2024 | 11:00 PM
Kracka's Avatar
Kracka
In or ft? Big difference.
Old Sep 8, 2024 | 06:52 PM
kromdom's Avatar
kromdom
Old Sep 11, 2024 | 02:00 PM
Andybump's Avatar
Andybump
Default Its inch pounds
13. Automatic Transmission Oil Pan Brace (3) >> Install [2x]
14. Automatic Transmission Fluid Pan Stud (2) >> Install NEW and hand tighten [2x]
15. Automatic Transmission Fluid Pan Bolt (1) >> Install NEW and hand tighten [13x]
16.
Click here for full size
17. Tighten fasteners in sequence shown.
18.
Automatic Transmission Fluid Pan Stud 10.5N-m (93lb-in)
Automatic Transmission Fluid Pan Bolt 10.5N-m (93lb-in)
19.
20. Wiring
To 2020 C8 Corvette
