Sponsored by: CARiD
Only shift to 6th when in track mode?
Old Sep 11, 2024 | 12:24 AM
vettman10's Avatar
vettman10
Cruise-In II Veteran
Default Only shift to 6th when in track mode?
I have been told that when in Track mode the DCT will upshift no higher than 6th. Is this true?
Old Sep 19, 2024 | 06:32 AM
Jacques Albrecht's Avatar
Jacques Albrecht
Gear 7 & 8 are considered overdrive. On most tracks keeping the RPM's up will be helpful to reach / use max HP so 6th is top gear.
Old Sep 23, 2024 | 03:15 PM
GP37's Avatar
GP37
at almost every circuit track you will not be going at a speed where using gears 7 and 8 will be ideal. you can shift into them if you choose to do so though.
Old Sep 23, 2024 | 03:17 PM
mikeCsix's Avatar
mikeCsix
In my C-6 GS, I only use 2-3-4, with 5 and 6 being over drive gears. That is for 6 different tracks.
To Only shift to 6th when in track mode?
