Sponsored by: CARiD
Cannot get into launch control
Old Sep 17, 2024 | 05:32 PM
AYC8's Avatar
AYC8
3rd Gear
Default Cannot get into launch control
Okay... To start, I've launched dozens of times in the past. It's a 2021 Z51 with magride. I've tried in track mode, sport mode, and Z mode. Yes, I am standing on the brake and flooring the accelerator. Yes, it is in PTM mode. I have changed the brakes numerous times for track, low dust without any issues in the past and it launched fine each time. I have zero codes when reading with my scan tool. Any ideas other than a trip to the dealership? (obviously a last resort) Thanks!
Old Sep 23, 2024 | 01:53 PM
BJ67's Avatar
BJ67
My simple method, start the car, leave it in park, dial in with the round dial to sport mode, reach up and click the traction control 2 times, you will get 2 yellow info icons, traction control off and ESC off. Put the car in drive, stand on the brake pedal and floor it.
Old Sep 24, 2024 | 11:22 PM
Misty C8 Z06's Avatar
Misty C8 Z06
steering wheel straight?
Old Sep 24, 2024 | 11:52 PM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
What is the process (step-by-step) that you use to launch (or attempt to)?
Old Sep 25, 2024 | 10:51 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I always put it into TRACK mode 1st--
Then click on the TCC 2 times and Stabilitrack yellow light should come on NOW both of them are ON yellow
Hold the brake pedal HARD--Keep the steering wheel STR8 and Do NOT let the car creep forward
It should rev up just past 3000 RPM's Hold the pedal at WOT then pop off the brake pedal
Depending on how warm the tires are If really warm you may get one chirp the launch
If the tires are not fully warmed up you may get 2 chirps but still in the low 3 seconds
Old Sep 26, 2024 | 12:03 AM
MarkMeHopeful
That sounds right, but I was asking the OP ( @BJ67 ) so we could try to help analyze what the problem might be.
Old Sep 26, 2024 | 10:54 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
This is what I do in my E-Ray. Z-Mode set to Track, PMT: Dry.
Can see my Z-Mode PMT: Dry setting and the Traction Control OFF Symbols. Press Z-Mode Button Twice and with left foot very firmly on Brake and WOT it goes to ~3500 rpm. Then lift left foot and "Hold On!"
Note to get that low # on GM Dash Test (GM subtracts dragstrip roll out like car mags, my guess ~0.2 seconds) I had:
  1. Battery at 100% charge NOT normal 80% by driving for >10 minutes in Z-Mode Power set to Track,
  2. Tire tread (all 4) heated, I do that when I turn onto my safe test street, farm fields both sides, no traffic start accelerating from ~10 mph @ WOT to 95+, applied brakes at ~0.8 "g,"
  3. Then Launch Control. Note perfect weather, low humidity and <1/4 tank. My passenger Remi' only weights 11 lbs - Loves Speed.
To Cannot get into launch control
