Sponsored by: CARiD
Installed Corsa Exhaust, Muffler Slightly Touching Diffuser
Old Oct 22, 2024 | 01:20 PM
liveralone's Avatar
liveralone
Default Installed Corsa Exhaust, Muffler Slightly Touching Diffuser
Hey guys, I spent the last few days installing the Corsa system on my C8. I wrapped it up today, and upon final check, I noticed both mufflers are slightly touching the lower diffuser/valence. They are not resting on it, just literally touching it. I went for a drive, checked the heat, etc, and it seems fine. Figured to throw a post in here and see if the consensus is to adjust it so it is not touching. Any suggestions would be appreciated.
On a side note, oh my god. The exhaust sounds incredible. If you are on the fence on a Corsa system like I was, do not hesitate. I am so glad I did it.
Old Oct 22, 2024 | 04:54 PM
jpmotorsport's Avatar
jpmotorsport
I have the same system but with a Verus diffuser and mine rests on it no problem.
Old Oct 23, 2024 | 07:44 AM
Ricketts's Avatar
Ricketts
I have same system, you have me curious now how close mine is. There is quite a bit of adjustment in that system where you might be able to remedy that.
Old Oct 25, 2024 | 08:18 AM
mikegr's Avatar
mikegr
I have the same system and it sits on diffuser as well and over a fairly short period of time just melted that lip on the diffuser and no more contact
Old Oct 25, 2024 | 09:50 AM
FORZAMOTORWORKS's Avatar
FORZAMOTORWORKS
Supporting Vendor
We've installed a bunch of them and haven't had any clearance issues - we've had to adjust/'massage' them a bit to get the fitment perfect, or close to it.
Old Oct 25, 2024 | 10:48 AM
liveralone's Avatar
liveralone
Got it. Yeah, I may need to remove the lower panels and just adjust it a bit. I don't think it needs much as it's barely touching. I thought about putting a small piece of insulation foam at the contact point but will just adjust it instead. Thanks.
Old Oct 26, 2024 | 07:27 AM
01Defense's Avatar
01Defense
Should not be resting on/touching anything. The heat will burn anything it touches.
Old Oct 30, 2024 | 12:55 PM
liveralone's Avatar
liveralone
Hey guys, so I ended up removing the panels on the underside and adjusting the exhaust. I managed to get almost half an inch of clearance. Thanks for the input. Definitely worth the extra effort to ensure things are done right.
On a side note, I do notice some water coming from the clamp areas when starting the car. I read through a few forums that it's normal, since the exhaust is not air tight unless welded together.
I still cannot believe how good the Corsa exhaust sounds. No videos I have watched have been able to capture the sound in real life. If you are on the fence, do not hesitate.
Old Nov 1, 2024 | 12:30 PM
FORZAMOTORWORKS
Supporting Vendor
Glad you got it sorted and agree, Corsa system is a must
Old Nov 1, 2024 | 12:40 PM
01Defense's Avatar
01Defense
Can you share some sound clips ie cold start, idling and drive by and in cabin
To Installed Corsa Exhaust, Muffler Slightly Touching Diffuser
