Hi i am a new member owning à C8 2020 z51 coupe. I have a problem with rear view camera and i am looping for the fuse location if anyone has teh information i will be thankfull.
thanks and have Nice driving day
Reason: Correct
The fuse associated with the rearview camera is located in the rear compartment fuse block, situated between the seats. To access this fuse block:
1. Open the top cover between the seats.
2. Push inward on the latch to release it.
3. Pull the cover upward to reveal the fuse block.
Within this fuse block, locate fuse number 27, labeled “Video Processing Module.” This fuse is responsible for the rearview camera’s operation. Inspect the fuse to see if it’s blown and replace it if necessary
