Sponsored by: CARiD
Lower Offset Wheels and Track Performance
Old Jan 16, 2025 | 03:09 PM
rza's Avatar
rza
Cruising
Default Lower Offset Wheels and Track Performance
Hi all, I've looked everywhere but cannot find a definitive answer to this question. I just picked up a 2024 Stingray Z51 w/magride that I'm going change the wheels on but also want them more flush with the fender. I'm going to get wheels that are the same size as stock except for the offset. However, before I do I'm trying to understand how those will perform on the track if I purchased ones with a 15-20mm lower offset than stock. Does anyone track their car on wheels with a lower offset and, if so, how does it perform? Are there any issues?
If it's not safe or will cause the car to drive worse, I could just add spacers and then remove them when I go to the track but I'm not even sure if that's possible because I've read that some spacers require shaving the stud down. Any advice would be great- thank you!
Old Jan 16, 2025 | 04:42 PM
X25's Avatar
X25
Sr.Random input generator
My 2 cents:
You should be fine. It increases leverage of tire over the suspension (i.e. making suspension feel softer), but if you're keeping the narrow OEM sizes anyway, I don't think it'd matter much if at all. If anything, slightly wider track might help in handling.
Old Jan 16, 2025 | 06:04 PM
breecher_7's Avatar
breecher_7
If you are going to buy wheels for tracking your car why would you buy factory sizes? The tire options are absolute trash. Go to a 18/19 or a 18/18.
Old Jan 16, 2025 | 07:14 PM
rza's Avatar
rza
Cruising
Originally Posted by X25
My 2 cents:
This is helpful. Thank you.
Old Jan 16, 2025 | 07:15 PM
rza's Avatar
rza
Cruising
I don’t track it very often - maybe twice a year. I run solo but am not that serious about it.
Old Jan 16, 2025 | 09:31 PM
SchnellC8's Avatar
SchnellC8
1st Gear
You'll need to worry about scrub radius if the offset of the wheel is changed. I haven't seen any specs on where the stock scrub radius is unfortunately. Maybe there is a way to measure without using special alignment tools.
Old Jan 16, 2025 | 09:33 PM
X25's Avatar
X25
On these cars, the shocks are pretty upright, almost perpendicular to the ground. I think the scrub radius is less of an issue due to this. I should also mention Z06/wide body cars also share this identical suspension geometry, and they employ wheels with offsets pushed about 25 mm outwards.
Old Jan 16, 2025 | 10:14 PM
RacerRik's Avatar
RacerRik
Shock position on double wishbone suspension systems has no effect on scrub radius.
Old Jan 17, 2025 | 03:30 PM
Dave135's Avatar
Dave135
I have really aggressive offset APEX SM-10RSs (35f, 44r), the car is a couple tenths quicker at Sebring with the same tire, and significantly quicker autocrossing. I suspect this is more due to the weight vs. the offset change.
It's also been 12 track days and the offset has not caused an issue with the shocks or otherwise.
Old Jan 17, 2025 | 04:12 PM
X25's Avatar
X25
Are they also wider wheels? Wider wheels significantly improve the contact area of tires, even for the same width tires.
Old Jan 18, 2025 | 10:44 AM
rza's Avatar
rza
Cruising
This is very helpful since I run Sebring as well. I was hoping someone could chime in that has actually done it. What size wheels and tires do you have?
Old Jan 18, 2025 | 12:13 PM
Dave135's Avatar
Dave135
They are wider yes.
18x9.5 et35 front
19x11.5 et44 rear
Using Cup2 265/315. Car has gone 2’23.0 Sebring, will drop a couple of seconds with a better tire. The Cup2 tolerate the rain much better though and this past season about half my events had rain.
Old Feb 10, 2025 | 12:00 PM
rza's Avatar
rza
Cruising
They are wider yes.
18x9.5 et35 front
19x11.5 et44 rear
Follow up question on this- do the track alignment specs change when the wheel has a lower offset?
Old Feb 10, 2025 | 02:37 PM
Dave135's Avatar
Dave135
No, it would not effect any alignment settings.
Old Feb 15, 2025 | 05:28 PM
rza's Avatar
rza
Cruising
Following up on this post. I ran the open track day at Sebring yesterday and had no issues whatsoever with the lower offset wheels (stance sf10 in stock sizes) or track alignment. Unrelated to this thread but still something to note is that the stock z51 brakes were ok, but didn't give me great confidence so I'll definitely change those next time I go. All in all it was great taking the car out on the track. It's not as fast as my old G80 M3 comp but it did handle better.
Old Feb 16, 2025 | 01:14 PM
PhoenixM3's Avatar
PhoenixM3
They are wider yes.
18x9.5 et35 front
19x11.5 et44 rear
I too went with -1” set up, but 18x10 et42 front and 19x11.5 et48 rear.
Old Sep 16, 2025 | 12:13 PM
Bravo-Four's Avatar
Bravo-Four
I went to a tire/wheel store pricing some Cup 2's and I was told i could go from 305/30's on the back to 325/30's which is a bit wider using the same wheel combination.
Is this ill-advised?? I imagine GM would have done this factory but there is a big price difference. I'm wondering if GM uses the 305's on the Z51 to save money instead of running the 325's.
Does anyone have any information in this area? Thanks so much for your wisdom.
To Lower Offset Wheels and Track Performance
