Sponsored by: CARiD
Cycling the ABS
Old Feb 2, 2025 | 02:14 PM
bhk2's Avatar
bhk2
Default Cycling the ABS
Hello, I am working my way back from the 43mph warning after bleeding the brakes-needed high temp fluid. I disconnected the battery prior to bleeding, but introduced air into the system. Tried the 20-30s push start button with no brake pedal but it only temporarily removed the warning.
My next approach involves these steps thinking I did not cycle the ABS:
1. Disconnect neg. terminal from battery
2. Manually bleed the system.
3. Reconnect battery
4. Re-bleed using scan tool to cycle the ABS system.
5. Restart using the 20-30 push button without brake pedal engaged.
Has anyone gone this way before? Thx.
Old Feb 8, 2025 | 03:59 PM
bhk2's Avatar
bhk2
Without a reply, the ABS cycling must not be a "thing." I followed the procedure as shown in the screen shot below and it removed all the dash warning icons with the exception of the yellow engine icon-left hand side of instrument cluster. New high-temp fluid installed using Motive pressure bleeder. I forgot which forum member created the Brake Reset Procedure Card, but it was not me.
