Sponsored by: CARiD
Turn Signal Hyper Flash
Old Jun 13, 2025 | 03:42 PM
Swanny's Avatar
Swanny
Default Turn Signal Hyper Flash
My left turn signal on my '23 HTC now goes into hyper flash and the DIC says "Check Left Front Turn Lamp". Has anyone else run into this and what is remedy?
Thanks in advance for any input.
Old Jun 13, 2025 | 05:55 PM
Citadel 84's Avatar
Citadel 84
Check the bulb!
Old Jun 13, 2025 | 06:03 PM
Swanny's Avatar
Swanny
Well, thanks for that!
From what I've read in other threads, the turn signal is LED and fixing requires replacing the entire unit.
Old Jun 13, 2025 | 08:32 PM
Scruff Vette's Avatar
Scruff Vette
There is a module behind the headlight with wiring connectors in front of the wheel well liner. The problem may be there, but most likely a problem with the LED in which case the entire headlamp assembly needs to be replaced. My drivers side DRL in the headlight was defective and stopped working after 200+ miles. The dealer ordered a new headlight and had it the next day. Had it installed and no problem since. Make sure the dealer had good techs. The front bumper needs to be removed to replace the headlight.
Old Jun 14, 2025 | 10:51 AM
Joe C5 C2's Avatar
Joe C5 C2
So this is "engineering progress". Probably at least $3,000 to replace a turn signal bulb. Just wonderful.
Old Jun 17, 2025 | 04:37 PM
Swanny's Avatar
Swanny
Update - this was self inflicted. When searching for switched power in the fuse box, I inadvertently left #47 out. It's one of the exterior lighting module fuses, which handles both the left front turn signal and the passenger tail light, both of which were out. Put fuse back in, works as it should.
Thanks to those who offered input.
Old Jun 17, 2025 | 11:55 PM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
The first question to always ask is "What has recently changed before the problem occurred?"
Old Jun 20, 2025 | 03:38 PM
ZORANGE's Avatar
ZORANGE
It's not a bulb...it's a light emitting diode (LED). Several of them, actually.
Old Jun 21, 2025 | 04:57 PM
Bob Paris's Avatar
Bob Paris
Cheaper to re-install the fuse that was removed and neglected to be put back in.
Old Jul 3, 2025 | 08:50 AM
Yeldawb's Avatar
Yeldawb
Veteran: Marine Corps
To Turn Signal Hyper Flash
