5,500 Trans Service
Posting on behalf of one of our club members, so please bear with me...
Just bought a 2023 C8 with 5,500 with no record of transmission service, and when we called the local dealer today, the freebie expired this past March. Was quoted $1,300 for a full trans fluid/filter service.
Should we do the service now or wait for 7,500 miles?
There is some evidence (strong evidence actually) that the engine oil life system "clock" will not start in this bulletin that describes, at a high level, the factors considered in the engine oil life calculation:
https://static.nhtsa.gov/odi/tsbs/20...02441-0001.pdf
which says
"The OLM starts its calculation for all pathways after the first 50 miles (80 km) to account
for marshalling and time before sale. Subsequently, calculations begin immediately after
each reset."
In other words, it would appear that GMs intent is not to start the clock until after the sale for engine oil life.
The transmission fluid life system does not even account for time or the three year requirement, so the owner has to observe that.
".... "The fluid needs to be changed after 3 years because the anti-foaming agents will break down and the fluid will absorb some moisture. All service recommendations are for good reason ."
Right or wrong, and I'm not going to debate that, the statement is from a GM rep and might represent GMs position on it - meaning they might assert that it needs to be changed.
To be clear, I am not saying it would or would not be harmful to the transmission, whether or not the transmission is sensitive, or whether the risk to the transmission is extremely low or not. In my opinion, that's not the point. The point is whether or not GM would deny a claim if have a transmission issue and the fluid was not changed for longer than three years from the day it rolled off the assembly line (or even if you took delivery and stored it for three years without driving it).
I think if I were buying a car that sat on the dealer lot for two years, I would want to have the engine oil and the fluid changed out - and I would have a lot more questions about why it was there for two years, and where it sat. Cars that sit a long time tend to collect critters etc. - so the question is bit hypothetical anyway.
$1300 is average for the cost, and would include a new filter.
(Perhaps $400 of that cost is the under panel Remove and Replace LOL)
The filter is about $200.
If you don't have the required 7500 miles, at a minimum at would change the trans oil at the 3 year mark.
Then again at 7500.
I would do the filter and oil now, and then again.
Here is a link to discussion that claims transmission fluid is hygroscopic:
https://wheelsbyjason.com/is-automat...d-hygroscopic/
He made sure I saw the DCT service, and said that it was NOT a DIY item. Corvette Connection in Denver said the same. It MUST be performed on time,
and at a Dealership to be logged into the vehicle service record, or you're on your own for any future problems.
- the owner's manual is clear a that you can perform your own service if you document it, and Josh Holder said that the DCT filter can be done DIY without the dealer performing the Hydraulic Flush Procedure. The dealer is just trying to do what many of them are good at - take advantage of owner's ignorance.
Josh's description (included below) of the HSF differs a bit from the Service Manual description (attached). Josh made it sound like all it does is "force more fluid through the filter". He did not mention the actuation of the solenoids in a specific manner to flush debris from the system. Note that he says that during normal highway driving a routine runs to force more fluid through the filter, but he does not say it is the Hydraulic System Flush routine (and earlier models did not even have the built in software to do the HSF). I do not believe that same HSF process can happen during normal or highway driving.
"Josh Hoder: The hydraulic system flush does kind’a the way its described. It forces transmission fluid through the fine filter that you replace. So, at a dealership they can hook up the dealer service tool to the and run a routine that will tell the trans control module to do this fluid filter flush. And because the car is already hoisted on the rack, the technician’s already got the panels off, there’s some other work he’s doing, this kinda happens in parallel in the background. So we’re doing it at a dealer visit because we can. And we can take the last bit whatever contamination might be in the oil and get it into the filter before the technician replaces it. Do it yourselfers have become nervous that hey now I can’t do it myself, I don’t have a service tool, I can’t force this routine. You don’t have to do the routine. Like I said we do it because we can, but the fine filtering routine happens during normal driving anyway. In fact, when you’re driving steady state like say down the highway, we run a routine in the transmission that will force more of that fluid through the fine filter. So normal driving is doing this. If you are a do-it-yourselfer, you don’t want anyone else touching your car, you can change the trans filter without running this routine."
Also, according to a GM bulletin about the oil life system (not the transmission fluid), the oil life system has a built in 50 mile delay before the countdown starts. So, at least for oil life it would seem that the clock starts after 50 miles which will typically be after delivery, rather than build date.
I found no similar documentation about the clock start for the transmission fluid replacement.
