Sponsored by: CARiD
changing oil technique
Old Jul 11, 2025 | 07:08 PM
DCortez's Avatar
DCortez
Default changing oil technique
Do you tightened bolts and oil filter by feel/hand or do you prefer using a torque wrench?
Old Jul 11, 2025 | 07:12 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Hand
Old Jul 11, 2025 | 07:35 PM
EvanD's Avatar
EvanD
CF Community Team
Torque wrench. Do not do the DCT filter bolts by hand.
Old Jul 11, 2025 | 08:16 PM
RKCRLR's Avatar
RKCRLR
I tighten the oil filter by hand to the required number of turns. All else with the appropriate torque wrench.
Old Jul 12, 2025 | 07:20 PM
wbear's Avatar
wbear
IMO it depends on the bolt and situation.
I learned over 55 years ago not to use a torque wrench on 1/4" size bolts and smaller since I don't like drills and easy outs.
I have nothing against torque wenches on larger sizes. I have a drawer full of them, 1/4" thru 3/4" drives.
My arm/hand is much more sensitive than a torque wrench when it comes to not going past the point of no return on the little ones.
I have never used a torque wrench on a drain plug and that includes my cars.
Oil filters as tight as you can get it with your bare hands. Never had one leak or hard to remove with a filter wrench and normal effort.
Would I recommend a 16 yr old kid just starting out working on cars to do everything by hand, no. It takes experience to develop the feel.
Lug nuts are one area where I always use a torque wrench unless I'm on the side of the road. Tip in case you didn't know: never use any lubricant on the threads or nut/wheel contact surfaces or you will over torque them. The torque listed in the manual is for dry surfaces.
Old Jul 12, 2025 | 09:03 PM
JDSKY's Avatar
JDSKY
Hand tight for oil pan drain plugs. Never had a leak or a stripped/damaged bolt in decades of doing oil changes on everything. I am currently doing annual oil changes on the C8, 2 lawn tractors, 2 snow blowers, 1 ATV, 2 UTVs and 4 snowmobiles.
Old Jul 13, 2025 | 03:54 PM
BJ67's Avatar
BJ67
By hand
Old Jul 15, 2025 | 12:13 PM
pltmgr's Avatar
pltmgr
Byhand but an old time machinist told me many years ago you have to develop a velvet touch.
Old Jul 15, 2025 | 03:37 PM
Phil1098's Avatar
Phil1098
Getting there is the thing. That sick feeling you get in your gut when a fastener goes from pretty tight to soft is horrible. I have the touch now after 50+ years of turning wrenches, but there was a learning curve.
Old Jul 15, 2025 | 04:48 PM
RKCRLR's Avatar
RKCRLR
Tighten it up until you feel it start to yield and back it off a little...(JK)
I use torque wrenches more often now that I have an appropriate one for most torques than I used to. I've found my "feel" is usually a little tighter than what the torque wrench says but sometimes it is looser.
Old Jul 15, 2025 | 06:38 PM
Phil1098's Avatar
Phil1098
Certain things REALLY are critical too. The oil drain plug on the block of an LT6 screws into the block, not an oil pan. The block is a two piece matched assembly. I will not risk stripping out the block because I was too stupid/lazy to use one of my seven torque wrenches I own.
Old Jul 17, 2025 | 06:19 AM
DCortez's Avatar
DCortez
Thanks guys, wrench it is.
To changing oil technique
