Sponsored by: CARiD
Tranny flush question
Old Jul 15, 2025 | 05:49 PM
bonnevillebill's Avatar
bonnevillebill
Default Tranny flush question
I took my ‘24 Stingray in for warranty repairs and the 1,700 mile tranny flush. My understanding is this requires domes special equipment to flush out the transmission plus change the oil and filter. I picked it after the service department was closed. The paperwork said they replaced the filter but nothing about a flush or new fluid. Did I miss a change in GM’s requirement?
As an aside, they changed the engine oil and filter without being asked. I did this myself last month. I know I get one change free, and I assume they will straighten that out.
Thanks for any thoughts.
Old Jul 15, 2025 | 06:45 PM
RKCRLR's Avatar
RKCRLR
People often misuse the term "flush". A flush is using flowing fluid to remove contamination and old fluid. Draining and refilling the transmission isn't a flush anymore than draining and refilling your engine oil is a flush. There is transmission flush equipment that is used to flush traditional automatic transmissions but that shouldn't be used on the C8 DCT.
There is no 1,700 service. The DCT filter needs to be replaced at 7,500 miles, 22,500 miles, and every 22,500 miles thereafter. The newer cars have a monitor that tells ypou when you are due for a DCT filter change. The DCT filter replacement procedure includes an internal hydraulic system flush that circulates the DCT fluid in a specific manner to move contamination into the DCT filter prior to replacement.
The DCT filter change interval is independent of the DCT fluid change interval and they may or may not coincide. There is no requirement to do them at the same time if they aren't due for replacement. The fluid change is just a drain and refill, not a flush. The DCT fluid needs to be changed every 45K miles or 3 years, whichever comes first (earlier if you track your car). There is a a DCT fluid life monitor but it doesn't track time so it is useless for most C8 owners.
Did you reset your oil life monitor when you changed your oil? If so, they should have seen that.
Old Jul 15, 2025 | 09:28 PM
bonnevillebill
Thanks for your response.
Old Jul 17, 2025 | 12:17 PM
mbando19835's Avatar
mbando19835
The 7500 mile to 9000 mile one is done free by GM. If you try and do it at 7499 you will have to pay for it. Do it at 7953 and it is free.
Old Jul 17, 2025 | 12:58 PM
EvanD's Avatar
EvanD
CF Community Team
None of this post is accurate. Neither the mileage you are saying nor what years have restrictions similar to what you are trying to say.
Old Jul 17, 2025 | 01:38 PM
mbando19835
so you are telling me the service department lied to me?
I took my car in for the an oil change and wanted to have the free service done and only had 7200 miles on the car. The service manager told me we can do it for you and it will cost $853. Go drive the car to 7500 miles and come back and GM covers it for free. Well, you know what I went back and it was free.
Please tell me how it was free then?
Old Jul 17, 2025 | 01:58 PM
RKCRLR's Avatar
RKCRLR
That would be a first...Not.
The requirement for the free DCT filter change on a 2024 and newer is the mileage needs to be between 7K and 8K miles. I believe they will also do it for free (or perhaps with a charge for an additional filter and some additional labor) with greater than 8K miles but then it is in violation of the 7K to 8K mile change requirement.
Old Jul 17, 2025 | 02:01 PM
EvanD's Avatar
EvanD
CF Community Team
If that is what they told you yes they lied. Actually, they probably told you the truth as they thought it was. So lied or clueless, you decide.
Read your owners manual and the letter Chevy sent to everyone if you don't believe me. Or your warranty benefits in your mychevy ap.
The DCT filter is due at 7500 miles and Chevy gives you a window of 7000 to 8000 to do it in. Do it at 6999 and by their letter you have to do it again in the mileage widow to keep your warranty. Not a window of 7500 to 9000.
Depending on year you could get it done early but that is not within the mileage to keep your warranty and you would have to pay for one between 7000 and 8000. Later years you could split the engine oil and DCT filter service and then they said they would only do it free if you had 7000 on the car. Year dependent. So the last part "If you try and do it at 7499 you will have to pay for it. Do it at 7953 and it is free." is also wrong.
And about "free". You or the original owner paid for these no cost services. Believe me they are not free. It's even on your window sticker as part of the standard vehicle price.
"The 7500 mile to 9000 mile one is done free by GM. If you try and do it at 7499 you will have to pay for it. Do it at 7953 and it is free."
Old Jul 17, 2025 | 03:12 PM
mbando19835
Multiple dealers told me that because I called around. Maybe my VIN has something to do with it. I am the original owner and my first oil change was free. Then, I paid for that 2nd oil change and that's when they told me I could either pay for the service at 7200 miles or wait until 7500 and it would be free. I waited and it was free.
If they ran the VIN in the system it would tell them if services were under a TSB, Recall or warranty.
I never received any sort of Recall or Warranty update letter from GM and am the original owner.
Old Jul 17, 2025 | 03:24 PM
EvanD's Avatar
EvanD
CF Community Team
So multiple dealers told you wrong.
Not sure how many on here have to tell you they are wrong for you to believe it. You are not the first to have been told wrong information from a dealers service department.
The letter from Chevy telling you about the specifics for the service intervals has been posted multiple times. Easy to find if you look. And as I said your mychevy ap will tell you the specifics about when you can claim “free” service.
The “free” services were not a TSB or recall. They are listed under warranty.
Either way your first post was incorrect.
Old Jul 17, 2025 | 03:55 PM
Andybump's Avatar
Andybump
What year do you have?
Prior to 2024 your free service was a combined oil change and DCT filter change and had to be claimed in the first two years. You can verify that in your Mychevy account which shows the status and terms of the free service. It can be claimed at any mileage and many have done it early including me at 2500 miles. But.....irrespective of the free service - you must have the filter changed between 7000-8000 miles even if done earlier. And, this information appears in the letter that was sent to all owners, for all years.
Starting in 2024, the free service was split into an oil change and a DCT filter change that can be claimed at different times. You have 2 years and no mileage limit to claim the free oil change. You have three years to claim the the free DCT filter change, but you must have at least 7000 miles to claim it. See the bulletin at this link.
https://static.nhtsa.gov/odi/tsbs/20...00117-0001.pdf
None of this affects or changes the required service intervals. You must change the filter between 7000-8000 miles to comply with the scheduled maintenance.
The 7500-9000 miles is very wrong - and in fact if you go beyond 8000 and do not change it, you risk a warranty claim denial if you have a transmission issue.
Old Jul 18, 2025 | 08:02 PM
EvanD's Avatar
EvanD
CF Community Team
With the C8 in its seventh year dealers still don’t know the car’s maintenance schedule. And it’s in their computer if they’d look.
To Tranny flush question
