Sponsored by: CARiD
Tune question?
Old Jul 28, 2025 | 09:20 AM
c5racr1's Avatar
c5racr1
Default Tune question?
Can the rpm limit be raised with a tune? if so, can I shift at that limit in Manual mode?
Old Jul 28, 2025 | 10:45 AM
combatninja's Avatar
combatninja
Tuners are claiming the ability the raise rpm limit in manual mode. Not sure how worth it is on an otherwise stock car as they are losing power above 6000rpm. With a cam and heads it probably makes a good bit of difference.
Old Jul 28, 2025 | 11:12 AM
Mr. Jonathan's Avatar
Mr. Jonathan
Veteran: Space Force
It’s push rod V8 so it’s not designed to rev higher. You want higher RPM, best to put your money in a Z06. Otherwise you’re spending a ton on internals and a tune.
Old Jul 28, 2025 | 03:10 PM
MCK_Z06's Avatar
MCK_Z06
The short answer is yes; you will still have to pay to get the ECU unlocked etc. which is not super cheap.
There is not much power to be unlocked with a tune on a stock car but yes you can raise the RPMs for manual shifting with a tune and the ECU transmission patch from HP Tuners. (You can't tune the transmission directly though.)
Old Jul 29, 2025 | 08:08 AM
Red Mist Rulz's Avatar
Red Mist Rulz
This. Is the LT2 an interference engine? If so, valve float caused by the mass of the pushrod valve train could get very expensive.
And this. The only advantage of revving higher would be in the rare instance where you need to shift at an awkward time on the track, and raising the redline lets you avoid that. But as quick as the DCT shifts, any gain would be minimal.
Old Jul 29, 2025 | 11:50 AM
c5racr1's Avatar
c5racr1
I'm going CAM, Heads, E85.
Old Jul 29, 2025 | 02:51 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Yes, multiple tuners have shown shifting above stock rev limit in manual mode. Supposedly, they are also close to having it for auto, but nothing confirmed yet. I've been very tempted to do cam/heads/E85 on my E-Ray, but I really want to wait for raised rev limit/shifts in full auto. I drive in manual most of the time, but for max accell runs, I'd want the auto shifts.
Yes, it is, but he's going cam/heads, so valve float shouldn't be an issue.
Old Jul 29, 2025 | 05:28 PM
Red Mist Rulz
Unless he's also going to lighter valvetrain components (pushrods, rockers, and valves), a more aggressive cam is likely to increase the risk of float, not reduce it.
Old Jul 29, 2025 | 05:42 PM
EvanZR1's Avatar
EvanZR1
Typically, you'd upgrade the springs when doing a cam to prevent float. But yes, all else being equal, going with a more aggressive cam does increase risk of float, but there are plenty of LS/LT engines pulling over 7K without issue.
Old Jul 29, 2025 | 06:06 PM
c5racr1's Avatar
c5racr1
I plan on going with the same setup that I had on my LT1. It pulled strong to 7200 for years. the current lt2 is more of a lt1.5 same heads.
Old Jul 29, 2025 | 06:12 PM
c5racr1's Avatar
c5racr1
If you are interested in what the Gen V engine I recommend you go to the Camaro 6 forum. small cube build LT1 turning 8500 rpm. Not rocket science, just packages.
Old Jul 29, 2025 | 07:11 PM
Quantumcruiser's Avatar
Quantumcruiser
The 1969 Camaro Z-28 could rev to 7500 RPM.
1969 Camaro Z/28: 7,500 RPM
1969 Camaro Z28 via Bring A Trailer
Specs
Engine
5.0-Liter V8
Power
290 HP
Torque
290 LB-FT
Maximum RPM
7,500 rpm
Overview
  • A de-stroked 327 was used for the Z/28s 302 cubic inch V8.
  • Grossly underrated at 290 horsepower, most put it at 350.
  • Built to compete in the SCCA Trans Am racing series.
In 1967 Chevrolet took their new Camaro and entered it against the Ford Mustang in the SCCA Trans Am racing series. Mustang had dominated its class since entering in 1965. To meet the engine restrictions, Chevrolet de-stroked a 327 to 302 cubic inches. Its advertised 290 horsepower was laughable, with most putting it at a more realistic 350 horsepower. It was not a big seller for the public initially in 1967 but, with over 20,000 Z/28s sold in 1969 and even more in 1970 it caught on in a big way. It was a favorite model that year.
Due to its tuning, it ran roughly under 3,000 RPM and needed revs to perform. The legendary Z/28 was born. It was extremely powerful for its size and propelled Chevrolet to class championships in 1968 and 1969, even defeating the Boss 302.
Old Jul 29, 2025 | 08:36 PM
Mitchell_B's Avatar
Mitchell_B
via Bring A Trailer
Specs
Engine
5.0-Liter V8
Power
290 HP
Torque
290 LB-FT
Maximum RPM
7,500 rpm
Overview
Talk is just talk. Popular Hot Rodding in a 1971 printing laid out an article where they took delivery of a stock 302 Z28 and Boss 302 directly from GM and Ford. Taken out of their respective shipping crates and run in on the dyno using headers on otherwise completely stock engines and in top trim with respect to fuel and spark, the Z28 302 put out 325 crankshaft HP at 6800 RPM and the Boss 302 put out 327 crankshaft HP at 6600 RPM. They went on to modify both to see how much power they could extract using factory parts. This was all extensively documented and I have a copy of the magazine with the 6 page article. Power numbers get inflated over the years, but I was there when these cars were being built, sold and run on the street and track. The power numbers Popular Hot Rodding got was real.
Old Jul 30, 2025 | 04:25 PM
ArizonaZ06's Avatar
ArizonaZ06
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Agree, prefer NA.
544hp 482tq wheel, no AFM. Manually shifts @ 7K.
Old Aug 3, 2025 | 12:54 PM
Kayvon D's Avatar
Kayvon D
Originally Posted by ArizonaZ06
Agree, prefer NA.
Nice, on 93oct or E85? Also ported stock heads? Who's work? (btw I agree this is the best setup for hardcore roudcourse work*)
Old Aug 3, 2025 | 09:47 PM
OkieVette84's Avatar
OkieVette84
What fueling upgrades do you plan?
You can tune for increased redline but only in manual mode, and from what ive heard - if its in auto mode and over revs, it throws CEL.
Can't confirm the mechanics on if/how/why on the CEL... as mine is set to stock RPM limits. One of the things I want to change though... my engine is safe to go 7500 but I want it set @ 7000 or 7200... the power is just there all day above 5800, so even if its just flat, I would appreciate the extra run out on gears 3 and 4
Old Aug 4, 2025 | 05:10 PM
ArizonaZ06's Avatar
ArizonaZ06
Detailed great build by Cordes Performance Racing.
Tapped out N/A. E85, LTX Cam, LME Heads, stock bottom end. Going to add two installation pics, just need to get proper files set up.
To Tune question?
Old Aug 5, 2025 | 03:16 PM
Kayvon D's Avatar
Kayvon D
Ever ran that badboy at the track?
Old Aug 5, 2025 | 04:14 PM
ArizonaZ06's Avatar
ArizonaZ06
1/4 in November, right now it's 110*+.
Old Aug 6, 2025 | 06:00 PM
ArizonaZ06's Avatar
ArizonaZ06
If anyone would like to see pics during the cam and head install just added to post #17.
