Sponsored by: CARiD
Z06 additional coolers on a Stingray?
Old Aug 13, 2025 | 04:26 PM
kgkern01's Avatar
kgkern01
Default Z06 additional coolers on a Stingray?
Has anyone added on the additional front radiator that the Z06 has to a Stingray for the extra cooling capacity? On a track I could see how having the extra cooling could be beneficial?
Old Aug 13, 2025 | 05:21 PM
Mark9's Avatar
Mark9
Add the V09 radiator. It goes in the air intake on the drivers side. There's a thread on this. I'll be doing this mod as my oil temps get too high on track. Don't know of anyone that has added an additional front radiator. It would require significant mods I suspect.
Old Aug 13, 2025 | 05:34 PM
68/70Vette's Avatar
68/70Vette
I've read that C8s sold to the Middle East countries have an added radiator due to the extreme heat encountered in these countries. Could this be the same radiator discussed here? Anyhow, looks like there's another radiator out there that can be added to a C8,
Old Aug 13, 2025 | 05:37 PM
Mark9's Avatar
Mark9
It's the V09 option. You can buy all the GM parts on line to install. Albeit a PITA.
Old Aug 14, 2025 | 10:17 AM
c5racr1's Avatar
c5racr1
I added the front radiator from the Z/Eray. It's not a direct bolt-on like the V09. But it works. I you want me to post some pictures, let me know.
Old Aug 14, 2025 | 03:43 PM
gtpvette's Avatar
gtpvette
V09 option - see post 61 for a GM engineer talk about all the cooling systems
How-to: Add 2nd Auxiliary radiator (a.k.a. V09 mod) - CorvetteForum - Chevrolet Corvette Forum Discussion
Z51 DCT Cooler
@c5racr1 I know you posted pic but can't find them,,, I'd like to know all the details if you don't mind.
Old Aug 14, 2025 | 04:59 PM
Mikeki7's Avatar
Mikeki7
The center crash bar/radiator bracket is different so its not a direct bolt on unless you also order that assembly as well. On top of that EOS makes a cool z06 replica center grill for the stingray bumper.
Old Aug 14, 2025 | 08:52 PM
c5racr1's Avatar
c5racr1
I used the stingray crash bar with some brackets and used the EOS center section. I first used the stingray center section and cut out the area behind the front license plate area for the duct. I just recently changed to the EOS center section.
Old Aug 14, 2025 | 09:03 PM
c5racr1's Avatar
c5racr1
This was the mounting, not the final bracket but close I rounded off the edges
This was the area I cut out of the stock Stingray license plate cover. I could reinstall the cover when I didnt want or need the extra cooling.
This was the area I cut out of the stock Stingray license plate cover. I could reinstall the cover when I didn't want or need the extra cooling.
This is the EOS replacement. I got the eBay equivalent for 200.00 fit and finish were fine.
This is the aluminum hose distribution block I got from the Z06 to channel the water the correct way.
This is the aluminum hose distribution block I got from the Z06 to channel the water the correct way. As far as a write-up, I don't have one. I just ordered the parts I figured I needed and got to work. It wasn't particularly hard, but it was involved. The only issue I have now is getting up to temp when it's cold outside. In New Orleans, that means 50 degrees F. Oil and water are cool on track 210 for water around 220 for oil in the summer. I did wind up putting a thermostat in the V09 because It was a solid struggle to get oil temp when on long interstate trips with no load on the motor. 140 degrees...a little too cool. Dm me is you want the ends and out and a parts list
To Z06 additional coolers on a Stingray?
