Sponsored by: CARiD
Z51 And slicks
Old Oct 11, 2025 | 07:32 PM
c5racr1's Avatar
c5racr1
Default Z51 And slicks
Are slicks too much for stock mag ride suspension?
Old Oct 12, 2025 | 03:00 AM
X25's Avatar
X25
Sr.Random input generator
Yep I'd think so, and there's no DSC controller to change magna ride calibration like we could on C7s...
Old Oct 12, 2025 | 09:34 AM
99vetteran's Avatar
99vetteran
Just run a drag radial the same size as your stock tires. The car doesn't know what tire your running, can't see any reason it would affect the Mag Ride.
Old Oct 12, 2025 | 03:24 PM
ZRacerLE's Avatar
ZRacerLE
He might be concerned with bottoming out the springs while cornering.
This guy is a pro that threw down a super fast lap on wider R7s with only a spherical bearing mod in the suspension (I believe). The dive of the car under braking is hilarious though. Not sure if a true racing slick would push the travel to the limits:
Old Oct 12, 2025 | 05:12 PM
c5racr1's Avatar
c5racr1
going to try some P1s and bring the slicks, probably Barber in November, not a real high-speed track.
Old Oct 12, 2025 | 07:58 PM
99vetteran's Avatar
99vetteran
Well I guess I misread it, I thought he was drag racing since he mentioned slicks.
Old Oct 13, 2025 | 07:51 AM
c5racr1's Avatar
c5racr1
road racing slicks.
Old Oct 21, 2025 | 07:15 PM
c5racr1's Avatar
c5racr1
I also had the dsc controller on my C7 GS. Just out of curiosity, what changes would you make on a DSC on a stingray? DSC says it is scheduled to be released at the end of the year.
Old Oct 21, 2025 | 07:22 PM
X25's Avatar
X25
It's been like that since 2020. When I reached out to them in 2023, they said the bus is encrypted and they can't unlock it.
Old Oct 29, 2025 | 09:33 AM
c5racr1's Avatar
c5racr1
DSC is unlocked
Old Oct 29, 2025 | 12:16 PM
X25's Avatar
X25
Originally Posted by c5racr1
DSC is unlocked
Could you please elaborate? Do you mean there is a new development, or that the DSC controller itself is unlocked? As I've mentioned, they mentioned it's the bus that's encrypted, which means the DSC controller cannot talk to other components (like the shocks) through the bus.
Old Oct 30, 2025 | 02:28 PM
C5racecar's Avatar
C5racecar
Bottoming out or dive under braking has everything to do with coil springs and suspension setup.
Yes, some sticky radial slicks will bring out the best and worst in the car.
If you are bottoming from elevation changes in the track, you need stiffer springs.
If you are nose diving under braking, you need adjustable shocks, or stiffer springs.
It is a delicate balance, too stiff, it doesn't work in the corners. Too soft and it nose dives.
Radial slicks are awesome. I had them on my C5 race car.
Like anything else in racing, if you make a big improvement in one area, then you will need to improve others.
Slicks > adjustable shocks > coil springs > urethane or solid suspension bushings > $$$
Old Oct 31, 2025 | 10:12 AM
c5racr1's Avatar
c5racr1
DSc is not totally unlocked; it's more of a piggyback style.
Old Feb 8, 2026 | 09:22 AM
c5racr1's Avatar
c5racr1
Its Here
Its Here
Old Feb 15, 2026 | 11:17 AM
Kayvon D's Avatar
Kayvon D
What Its Here
Its Here
What exactly does this do!?
Old Feb 16, 2026 | 08:13 AM
c5racr1's Avatar
c5racr1
It allows the end user to adjust the shocks to make them tunable.
To Z51 And slicks
