Sponsored by: CARiD
alternative DCT fluids
Old Oct 23, 2025 | 08:20 PM
cmck0916's Avatar
cmck0916
Originally Posted by RPOZ4Z
The GM fluid is the color of regular motor oil. the Valvoline fluid is red.
which is why I asked the question, IF you use the Valvoline fluid, they will know.
Simple solution: if you have a transmission problem, drain the Valvoline fluid out and put the ACDelco fluid in before bringing it to the dealer for warranty work.
Old Oct 24, 2025 | 08:06 AM
EvanD's Avatar
EvanD
CF Community Team
Not so simple as about 4 liters of fluid doesn't drain out. If they wanted to push the issue of not using AC Delco fluid it would be easy to test.
Old Oct 31, 2025 | 02:04 AM
X25's Avatar
X25
Sr.Random input generator
I use Amsoil, and it seems to be the same color as the AcDelco variant. I use Amsoil, since it's (supposedly) a wee bit better in high temp and heavy duty use tolerance, and I mainly use the car for track. It's also priced well with their cheap annual membership.
