Sponsored by: CARiD
Service safety restraint system
Old Oct 30, 2025 | 06:54 PM
A10Beav's Avatar
A10Beav
Default Service safety restraint system
This warning has popped up, without any associated codes. It happened after I installed a harness mount under the passenger seat. I didn’t disconnect anything, just raised the seat enough to clear the rear bolts. So I’m guessing it’s associated with that. It’s been through multiple drive cycles and hasn’t cleared.
The harness connection under the seat seems tight. Are there any options for me to clear this?
Old Oct 31, 2025 | 08:36 AM
patton's Avatar
patton
St. Jude Donor '09
go back over your work the ECM does not like something you did and even if you find it it might need a scan tool to re-set it
