Sponsored by: CARiD
good scanner for c8
Old Nov 1, 2025 | 09:29 AM
bpk1959's Avatar
bpk1959
Default good scanner for c8
looking for info on which scanner to buy. not looking for anything exotic. but, something that knows all the c8 codes
Old Nov 1, 2025 | 10:51 AM
Bburr's Avatar
Bburr
It would probably work better if you said for which C-8. There are differences, especially with the DCT!
Old Nov 1, 2025 | 11:03 AM
kromdom's Avatar
kromdom
reads DTCs and more:
https://www.corvetteforum.com/forums...se-clones.html
bpk1959's Avatar
bpk1959
24 z51 stingray
Old Nov 1, 2025 | 11:46 AM
99vetteran's Avatar
99vetteran
You could just buy HP Tuners Mpvi 4. It's about 400 bucks. MPVI4 – HP Tuners
I have Mpvi 2 which I've used on my other GM cars and trucks. I need to upgrade to log and maybe someday unlock the ECU and tune the C8.
Old Nov 3, 2025 | 01:51 PM
sean.b's Avatar
sean.b
a far shadier route that I cannot recommend in good faith, but.. if you look for "vnci mdi2" harnesses, for right around the $200 range, they'll run all of the GM/Bosch software.
Old Nov 10, 2025 | 08:06 AM
carryspeed's Avatar
carryspeed
https://www.foxwelldiag.com/products...48431575728410
Old Nov 15, 2025 | 06:16 PM
99vetteran's Avatar
99vetteran
I was able to scan with my HP Tuners Mpvi2. You can log about anything you want except E85 content since there is no Flex Fuel sensor.
Old Nov 16, 2025 | 11:37 PM
C5racecar's Avatar
C5racecar
Are you looking to collect engine data, or just to scan if you get an engine code?
Old Nov 17, 2025 | 07:52 AM
99vetteran's Avatar
99vetteran
I'm running E30 so I'm keeping an eye on fuel trims. I did have a couple lean codes when I ran the E30 in cold of conditions. I already have HPT from tuning my other cars, so might as well use it. I'm not sure why I couldn't turn off the check engine light after I corrected the fuel trim lean conditions. I like to see what kind of timing it is running at WOT, I hope to someday unlock the ECU to do some tuning on it and add a Flex Fuel sensor and truly tune it on E85, E65 in our area.
To good scanner for c8
