C4 of Year Winner (performance mods) 2019
Originally Posted by DBLX01
So what cell cats should I go with that wont send codes? Any cat recommendations?
Originally Posted by breecher_7
Yup, straight pipes or gut the stock cats... Get rid of them. They choke your engine.
Modern cats don't really lose much HP. I think those doing sport cats are seeing 5-10HP. And finding some that won't set a code can be difficult as I've seen people with even the Corsa and other 400 cell sport cats occasionally throw a CEL. Going 200-300 cell will definitely require using an O2 simulator. Going catless will make your significant other (if you have one) never want to ride in your Corvette again (or at least complain about it every time they do ). For the price, you'd be much better off doing a FlexFuel setup as that will give you some real gains. FlexFuel (E85) will gain a solid 30HP on a Stingray, but the cost isn't cheap at a little under $5K (biggest cost is in the tuning, which is why I'd save for a blower, as that needs tuning as well, so you could do blower and Flex at the same time to save some $).
My car is on flex and without cats…
Cat delete alone is worth a solid 20hp. Look at a factory cell and tell me it’s not restrictive…
FYI, you can do flex a lot cheaper if you do it yourself. Using a DSX installer and being married to them is not the only option.
I’m going to do a 14:1 440ci sleeved block. I’d rather make 700+whp all motor than with a blower or turbos.
Looking doesn't really tell you anything about how restrictive they are. C8 uses the same cats for LT2 & LT6, so if they flow good enough to support 670HP LT6, I seriously doubt they are a significant restriction. I'm not going to go dig up the posts, but I remember seeing 5-10HP when people dynoed before/after (which is what Google AI result says as well), so would love to see a dyno showing a 20HP gain just for going catless.
Originally Posted by OLD_GOAT
Cat delete cars supposedly smell like gas and are way too LOUD.
Best bang for the buck, around $4,600 is a dual fuel E85 tune. Here are my results on a heart breaker Mustang dyno.
Yes, going catless will add a very noticeable smell. I don't mind so much, but I can definitely notice it (and my sense of smell isn't great). My wife has a much better sense of smell, and she would complain every single time.
Nice solid 30HP gain with the E85. If I mod my E-Ray, that'll probably be the first thing I do since we have E85 readily available.
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Have greatly enjoyed the 93% efficient hi-flow HJS 200 Cell Cats from Fabspeed over 5 years now without ever ONE CEL. Never a CEL comes from the high amount of rare earth minerals found in the HJS Cats. Just to confirm the OEM Cats have 700 Cells of flow.
Old Goat, Breecher and DBLX is E85 Best Bang correct. My LT2 PCM E85 Flex Tune brought 484rhp/466rtq from Cordes Performance Racing in 12/ 2023.
This is exactly my long term goal for mine is as well. I have a 95 TransAm with a 14:1 396 LT1, and that high compression NA power is fun
I agree with everyone else's statements, the best bang for the buck "bolt-on" is an E85 Flex tune, its a consistent 25-30rwhp gain on these cars. A lighter and better flowing catback and air intake are up there as well, but you already have those
If you never intend to go beyond a bolt on car, then headers may not be worth it performance wise, and if you do anyways, make sure you use a brand that actually uses 1 7/8" runners and 3" collectors, I know ARH and Speed Engineering both are actually full 3" at the collector. A lot of the C8 headers out there have small stock size 2.5" collectors. I went with Speed Engineering ones, and for $500 for good quality stainless headers, isn't too bad of a deal.
Headers are never worth it until you line up next to someone who has them and you don't. Some folks know better. They're the ones driving away from you to display their taillights.
Some of the best shops in the country have posted honest back to back dyno results running with stock manifolds vs headers. On a bolt on car they are absolutely NOT worth buying. Bumped Compression, CNC'd Heads and Cam with a PTR Intake and tuned on E85, then yes, get them.
So do you have before and after time slips? DA data to give a clear picture? Or a draggy run?
I'm in the beginning stages of messing with my Eray. I have a Soler TB, Soler controller, AFE intake, ported intake manifold, MBRP valved exhaust and a Fuel-It Bluetooth ethanol analyzer. It's nice to be able to look at my phone and see exactly what my mix is. I've tuned hundreds of C7s but don't want to spend the time learning the Global B platform. I'm getting too old for that. Graham, at Paragon, wrote a 91 Octane "burble" tune to go along with all the mods. I can run E30 on it as well. I also have a full E85 tune for it. Both are a big difference from stock and the "burble" is just right.
I'm sort of debating on going full Flex. I can swap tunes in just over a minute. If I don't, I'll probably add a dedicated E30 tune with more timing.
I'm an American Racing Headers dealer, and I'm still not sure about adding those.
__________________ PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036 WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
You work for A&A...where is the BOOST sir? 😍
__________________ http://www.corvetteexhaustsystems.com sales@corvetteexhaustsystems.com
201-575-0861 (cell to call or text)
Your Ultimate Resource For Headers, Exhaust Systems & more for Corvette! I carry Corsa, Kooks, ARH, Borla, Billy Boat, Akrapovic, Capristo & Much More
I don't "work" for A&A. Hell, I barely work at all anymore. 😀 I started A&A 25 years ago.
I bought my first C8 back in 2021 with the intention of building a system for it. I decided not to do it due to the price point and the time and effort it would take to do it right. THEN I'd have to go through C.A.R.B. certification all over again! That is something I never want to go through again.
I'm quite happy selling 550-600 C5, C6 and C7 systems a year and having time to travel and enjoy myself.
Enjoy the freedom I'm enjoying my A&A Kit on my C6Z! Yeah it's pretty crazy how much a C8 supercharger kit is these days vs previous generations.
Andy I got to admit I was sad to not see you jump into this Market! Your YSI kit for the C5/6 ran like a raped ape.
I was surprised you did not come into the C8 market but we all have to draw a line somewhere. I have had many of your systems and they are where great! Hope you enjoy some down time and keep selling the other systems! Pay for that travel ha
