Hello,
I'm on the fence about adding LT headers. I know I will get added performance benefits but is it worth it? Can you share your experience if you have upgraded? Currently I have Solar performance throttle body, Borla Atak exhaust, Haltech intake, and Solar perf throttle controller.
The next thing would be headers.
Also, with several header options available, which is the best to go with and why?
Hello,
MJ
TIA,
Headers are worth 0 on a bolt on car. Maybe there is a random car that legit gained a tiny bit, but we have back to backed it multiple times with multiple brands.
The only combo we have ever seen gain with headers was a heads/cam setup and it was worth 12-15 wheel depending where in the powerband you were looking.
C4 of Year Winner (performance mods) 2019
Honestly, headers haven't been worth it to me since the C6 (Z06/ZR1), as everything since then has essentially been shorty headers for the exhaust manifolds. Will you get a gain with headers? Yes. Will it be big? No. Is it worth the cost? It's up to you, but for me, it would only be worth it if I were doing a max effort bolt-on build.
Hello,
MJ
TIA,
Not so fast sir. The fastest NA C8s with no heads/cam have headers with bolt-ons at the drag strip. Dyno numbers only give you an idea where your car stands with other cars, which is a good thing. That 12-15 wheel horsepower definitely translates at the dragstrip for what it's worth. And I am saying this because, I have spent a lot of time with my bolt on C8 and others at the dragstrip. Now I can agree, just installing headers without any supporting mods then you may see nothing.
A dyno number does far more than tell you how you stand with other cars. I'm not new at this and a little research would tell you I most certainly have a lot of experience to make the statement I did.
I stand with my statement as you do yours. I was just trying to make an input with the OP. I don't have to do any research because I do my own test/tune without dyno numbers. Also, I know that you have a reputable shop
Lets say this if you are only doing headers save your money. chev on this car did a good job with the set up on this exhaust on the headers. now if you will be doing a full exhaust a diff air box port the intake and heads and cam then yes. This air box on the c8 is a piece of crap also the exhaust is also from the weight stand point. The air is not all that good much better out here. But to me the exhaust is crap from a weight stand point also...
Very interesting takes and thanks for the feedback! I do have the halktech intake, Solar performance throttle body, and Borla Atak exhaust. All the responses make sense from the POV's.
Ive been thinking about a Supercharger at some point. If I jump in that direction, I guess it would make more sense to do it then? Just dreaming about the SC right now.
Originally Posted by DBLX01
...Ive been thinking about a Supercharger at some point. If I jump in that direction, I guess it would make more sense to do it then? Just dreaming about the SC right now.
You really don't need them with a blower. There were multiple people who tested C6 ZR1s stock manifolds vs long tubes, and really didn't gain a lot. If I remember correctly, the stock manifolds weren't really a restriction until 800-900HP.
Oh wow! That’s great data. I wouldn’t be reaching that high in the hp category.
So if I scrap the header interest now, is there any other bang for the buck performance improvements I can make?
If you're thinking about a blower, I wouldn't spend any other money on bolt-ons. Save all those dollars for the blower as that will be the biggest jump in HP. And you may want to spend extra for items to go with the blower such as a FlexFuel setup/tune to be able to run 93 and E85.
DBL. I failed to notice that you already have the catback. I now will agree with Breecher 7. With your currently mods, you should see a tremendous difference in power gains with the E85. That may change your mind for the supercharger.
C8s have tubular exhaust manifolds.... headers. from factory....
Here is a side by side, American Racing (Left) stock (Right).... the most even claimed is like 20hp... and we all know claimed vs reality. Let alone price vs 20hp. Sure if you have unlimited funds, and want every single HP. Then sure. But it would be WAY down the list of mods to spend money on.
They factory manifolds are a FAR cry from the old C4/5/6 days
