Sponsored by: CARiD
E85 blend to E20 to help with slight ping/knock
Old Jan 10, 2026 | 12:29 PM
dstewart51's Avatar
dstewart51
Default E85 blend to E20 to help with slight ping/knock
In CA, we can only get 91 and often that's with 15% ethanol already. I have noticed in the upper gears at lower RPM, slight throttle a faint but recognizable knock and pre ignition ping. Ive tried a few different gas stations with the same results. So out of curiosity and just an experiment I added about 2.5gal of E85 to top off a tank of 91. This should have got me close to E20 and about 93oct. Not heard the ping/knock since! No other issues as a result.
Old Jan 10, 2026 | 01:48 PM
breecher_7's Avatar
breecher_7
You should be good up to E30.
Old Jan 10, 2026 | 03:26 PM
Mike Jesse's Avatar
Mike Jesse
Both my Stingray and ZO6 I have blended it to about E30 with no ill effects.
I have 92 in my area but blend it when I go to the track.
Old Jan 11, 2026 | 08:39 PM
C8HTC2020's Avatar
C8HTC2020
I am in SoCal also and have noticed the knocking when I am chilling on the highway in auto mode and the AFM 4 cylinder mode kicks in and there are mild hills where the knocking occurs on the inclines. When this occurs I pop out of auto mode and generally downshift.
interesting idea to mix E85.
Old Jan 11, 2026 | 09:01 PM
dstewart51's Avatar
dstewart51
It cleaned the knocking right up. Think Ill try to stick with ~E20 from now on if the station has E85 on hand.
Old Jan 13, 2026 | 05:20 PM
99vetteran's Avatar
99vetteran
I ran E30 from the pump at our local stations. They have E15, E30 and E85 (E65 to E67 is what we actually get at our pumps). I didn't have any issues till our temps started coming down here in Missouri last fall. Once it got down into the 30s at night and I'd go out to start the car, once I started rolling the check engine light would come on. It was just too cold for even E30 with no FF sensor. So, I'm back to running premium till spring when the temps start to rise again. I love E, yes you'll get a few miles less, but you're going to gain around 15 to 20 rwhp. These cars have wide bands so they can make some adjustments to compensate for the additional ethanol over E10 which is pretty normal now at any service station. I ran E65 in both my 2022 Camaro and C7.
Old Jan 20, 2026 | 11:21 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
I run E30 all the time in my Eray. It works great. I have a Fuel-It Bluetooth Ethanol Analyzer plumbed into the system. I can check my Ethanol mix on my phone. It's pretty cool. I also have a full E85 tune that I run sometimes as well. The station I use has E85 that is actually E85, not E67 or something.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old Jan 20, 2026 | 01:45 PM
Fore58's Avatar
Fore58
Question sir.....I just want to do the 93/E85 mixture not to exceed E30. Can I use the Bluetooth Ethanol Analyzer without the tune just to measure the mix only. Thanks
Old Jan 20, 2026 | 03:30 PM
99vetteran's Avatar
99vetteran
I think most have found the blend line to be about 3 gals of E85 if that's what your station actually has (mine are E65) and 15 gal of 93 to get somewhere around E30.
Old Jan 20, 2026 | 06:03 PM
Fore58's Avatar
Fore58
Okay that's base on a full tank. I didn't know that one and that's good to know.
Old Jan 21, 2026 | 07:34 AM
99vetteran's Avatar
99vetteran
Too bad your stations don't have the E30 at the pumps like ours, it takes the guess work out of it. According to the guy I talked to that checks all the fuel at the stations in Missouri to make sure they are complying with what's on the pumps, the E30 is 93 to 94 octane,.
Old Jan 21, 2026 | 08:30 AM
Fore58's Avatar
Fore58
I see. We have 93 octane in Florida but is it actually 93 at every station is the question.
Old Feb 17, 2026 | 01:27 PM
superramvette2's Avatar
superramvette2
No issues on my z06 w e30 but I don’t run all the time.
To E85 blend to E20 to help with slight ping/knock
