Sponsored by: CARiD
Another Wheel Thread
Old Feb 19, 2026 | 04:05 PM
EVL-C8's Avatar
EVL-C8
Default Another Wheel Thread
I have a 2021 C8 Z51 and want to put wheels on with a 14mm less offset in the front and a 16mm less in the rear.
Will they work or will they rub with stock the tires?
Stock front rims are 19x8.5 52mm offset Rims I'm wanting are 19x8.5 with 38mm offset and will stick out .55 inches more.
Stock rear rims are 20x11 64mm offset Rims I'm wanting are 20x11 with 48mm offset and will stick out .63 inches more.
Will be putting stock tires on them. Company says they work but I want to ask actual Corvette owners first.
Thanks!
Old Feb 23, 2026 | 02:52 PM
TheBlauv's Avatar
TheBlauv
Default Offset
Thanks!
I went with 38/48 with stock tires and was a perfect fit. Front and rear were sat inboard of the fender approx. 1/8 “. Exactly the look I was after.
Old Feb 23, 2026 | 02:57 PM
TheBlauv's Avatar
TheBlauv
Old Mar 1, 2026 | 09:06 AM
Chris in SoFlo's Avatar
Chris in SoFlo
7th Gear
Beautiful car. Are the wheels MRR F23? How do you like them? Have you used them on track? I’m considering the F23 for track use.
Old Mar 1, 2026 | 09:10 AM
99vetteran's Avatar
99vetteran
Originally Posted by TheBlauv
Now you just need to lower it to take up the wheel well gap. Although with the way the offset is the tires may rub.
Old Mar 1, 2026 | 06:23 PM
TheBlauv's Avatar
TheBlauv
Those are Gem Motorsports G8Z wheels.
Old Mar 1, 2026 | 06:24 PM
TheBlauv's Avatar
TheBlauv
To Another Wheel Thread
