Sponsored by: CARiD
C8 Trans Torque Limit?
Old Apr 20, 2026 | 03:38 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default C8 Trans Torque Limit?
Does anybody know what the design torque limit for the standard DTC is ?
Old Apr 20, 2026 | 05:08 PM
Andybump's Avatar
Andybump
following
Old Apr 20, 2026 | 05:16 PM
Andybump's Avatar
Andybump
DCT
590 lb ft
https://www.corvetteactioncenter.com...literature.pdf
Old Apr 20, 2026 | 06:27 PM
VinnyP's Avatar
VinnyP
Features at a Glance:
• Continuous torque over a wide ratio range allowing high performance driving and efficient highway driving
• Over-torque shifting with torque boost for performance launch
• Offered with mechanical or electronic limited slip differentials
• Torque capacity to 800 Nm (590 lb-ft)
• 7,500 RPM maximum input speed
• ISO 26262 and ASIL-D safety standards compliant
Am I missing something here. 2nd line from the bottom states max rpm is 7500, meanwhile the LT6 redlines at 8600.
Old Apr 20, 2026 | 06:55 PM
Andybump's Avatar
Andybump
Well, this flyer was before the LT6 (date is 2019 actually at the bottom of the page). He did ask about the "standard" DCT. I believe that the transmission in the Z06 has been beefed up a bit to accommodate the higher RPM.
Old Apr 20, 2026 | 07:38 PM
Andybump's Avatar
Andybump
Adding to post 5, here are the Z06 upgrades. In addition to beefed up components, it mentions the "track ready oil level - 2L extra not needed." To be clear about that, it does not contain 2 extra liters of fluid. As Josh Holder explained, the case and pan were modified to better hold the oil near the pick up point. And, that particular change, introduced in the 2023 Z06, was also introduced in the late 2023 SR.
https://gmauthority.com/blog/2022/05...-transmission/
Old Apr 21, 2026 | 05:03 AM
VinnyP's Avatar
VinnyP
Thanks for clearing that up. I didnt notice that tiny 2019 on the bottom of the page. Eyes arent as good as they used to be.
Old Apr 21, 2026 | 03:39 PM
BPHORSEGUY's Avatar
BPHORSEGUY
To be clear I am asking about the standard DCT FOR Stingrays
Thank you all !
To C8 Trans Torque Limit?
