Question: Soler Throttle Controler
USE CASE: I install and set a Soler Throttle Controller to Sport 5. I set my drive mode to "Tour" and press the accelerator. I then set my drive mode to Track and press the accelerator. As a result one of the following are True:
- My throttle map and throttle response will remain the same because I set the Soler Throttle Controller to Sport 5 regardless of drive mode.
- My throttle map and throttle response changes because my drive mode changes. But, my throttle map and throttle response is different than OEM because I have a Soler Throttle Controller installed and set to Sport 5.
Which one is true?
