Now Available: Soler Performance 92mm Throttle Body for C8 Z06
Engineering that delivers - Performance - Design - Quality - Customer Care - Like no other
Don't settle for anything less.
Soler Performance is proud to release the largest throttle body currently available for the C8 Z06. Our new 92mm unit is engineered specifically for the LT6 platform and is now available in two finishes:
• Black Anodized: long awaited
• Polished Billet.
This is a direct bolt on upgrade for the C8 Z06.
No adapter required
No tune required
Warranty safe
1 year warranty (3 year optional)
The first & only high-performance billet throttle body for the C8 Z06 in the world!
SE3793-92 C8 Z06 92mm Throttle Body
TYPE:
NEW. Brand new custom part, 0 miles, BNIB.
PERFORMANCE Per Unit:
Wide Open Throttle Flow: 1200 +/- 20 SCFM at 20.4 inches of H2O
FEATURES:
• Smooth Streamlined Custom Design
• 6061-T6 Anodized Aluminum Construction (Polished or Black Finish)
• Greater Discharge Coefficient of Plate/Blade interface
• Shaftless high-pressure side of the blade for Larger WOT Flow Area
• Dome and Thread-locked Screws
• 16 Ra Microinch, Diamond Polished Surface Finish
• Self-Cleaning Throat/Flow Gap
• Dimpled shaft trailing edge
BENEFITS:
• Increased airflow to support the high revving LT6 (+230 SCFM, or 24% over Stock)
• Improved throttle linearization for more precise control
• Immediate response right off idle with no hesitation or stumble
• Increased airflow and power at every throttle position after idle
• No tuning required, but can benefit from a tune if desired.
Recommended Pairing: SE0525 Throttle Controller
The Soler Performance Throttle Controller pairs perfectly with the 92mm throttle body, allowing you to further fine-tune throttle response and pedal sensitivity.
WHAT’S INCLUDED:
• A set of two Throttle Bodies.
• Accessory Bracket for Connector (1x).
• Throttle Body Screws (8x).
Tested and Proven to fit in conjunction with Listed Intake Kits:
- Eventuri
- Halltech Super Hornet
- JLT
- CORSA
- Factory OEM Intake
Forum Discount Code: TIFF5OFF
Black Anodized or Polished Billet… which one are you going with?
Soler Performance LLC
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
SE3793-92, C8 Z06 (92MM BILLET). LT6 [2023+] SET OF 2 — Soler Performance LLC
Discount code: tiff5off
