C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
FPC article
Old Apr 27, 2021 | 12:41 PM
GrandSport 2017's Avatar
GrandSport 2017
Originally Posted by ZRacerLE
So is it over or under 3600lbs? Blink once for over and twice for under.
I have no idea the weight of the car. I'm an "engine" guy.
Old Apr 27, 2021 | 01:11 PM
RedLS6's Avatar
RedLS6
Originally Posted by GrandSport 2017
The hot mod soon will be putting the truck crank in the 5.5
What's the difference in the truck crank?
Old Apr 27, 2021 | 01:47 PM
ZRacerLE's Avatar
ZRacerLE
Gotcha. Worth a shot. So at least we know it's 672hp.
Old Apr 27, 2021 | 04:47 PM
Latterlon's Avatar
Latterlon
Originally Posted by RedLS6
.....My guess hasn't changed, I still think it'll be a short stroke/long rod combination, ~3.2" stroke to help lessen the secondary combined with a ~4.07" bore if it's a 5.5L. The stroke gives piston speeds at 8000-9000rpm that are within the realm of "it's been done before", while the bore should allow some great flowing heads/valves.....
Agreed. Also interesting to note that these bore/stroke measurements are essentially the same as the 4.0L 911 GT3 engine. A good thing.
Old Apr 27, 2021 | 05:49 PM
JABCAT's Avatar
JABCAT
Originally Posted by Rkreigh
The GM engineers have their work cut out. A brand new engine with FPC sounds like they are walking the same path as ford, which dropped it like a bad habit
curious what magic GM engineers can work that ford didn't think of. They aren't dumb over there either!
If they do decide to go this route, I fear we’ll see posts in the near future similar to those directed at potential C6 Z06 buyers, ie “make sure you get the xyz engine component checked out before purchase, or budget to have it fixed right away”.
Originally Posted by jim2527
Ferrari seems to be doing ok with their FPC DOHC V8’s that make big power.
4.7l & 600hp
Ferrari doesn’t have to make 40k engines annually, and a vast majority of owners rarely drive their vehicles. Not even close to being a valid comparison to Corvette.
Old Apr 27, 2021 | 06:19 PM
Z0HS1CK's Avatar
Z0HS1CK
And you been singing the right tune the entire time!
Old Apr 28, 2021 | 07:46 AM
vettesweetnos's Avatar
vettesweetnos
I could live with 672 hp at 3600 lbs. Especially if geared correctly. I would say the ZR1 is years away still, at least 5, so it is confusing how we seen the tt cad leak so early.
Old Apr 28, 2021 | 09:47 AM
GrandSport 2017
I wouldn't think its 5 years away.
All versions of the Gen6 engines were, for the most part, developed in parallel. It wont be the engine hardware that dictates the release timing of subsequent versions.
I don't know, but I would think that the new sub components like suspension, brakes and tranny are what will dictate the time lines for release of the subsequent versions.
I would think they they are also the primary drivers of cost of new versions because they are not shared across platforms like the engine.
What would you guys think of a cross plane crank 32valve 6.x L re-cammed version with a red line of 6900 rpm to replace the LT2? Slightly more hp but MORE torque.
I read "on the internet somewhere" that they would need to make a certain number of these small port lower hp heads to meet some kind of racing rules somewhere.
Old Apr 28, 2021 | 09:50 AM
ZRacerLE's Avatar
ZRacerLE
"Horsepower sells cars, torque wins races"
-- Carroll Shelby
Old Apr 28, 2021 | 09:52 AM
GrandSport 2017
Well if you were putting the engine in a truck what would you do to the crankshaft?
Old Apr 28, 2021 | 10:38 AM
RedLS6's Avatar
RedLS6
Probably switch to a cross plane, increase the stroke from "3.2" to 3.6 (or what worked depending on the deck height / rod length). This gets about 6.1L.
The issue I would see with an owner swapping a crank like this into his FPC 5.5 C8Z would be the firing order change, and the ECU.
Old Apr 28, 2021 | 10:45 AM
OnPoint's Avatar
OnPoint
The Consigliere
I"m really, really hoping the ZR1 gets a cross plane crank and twins. Would be nice to have that as a strong power package in an engine I wouldn't have to worry so much about it living to 50k miles.
Old Sep 13, 2021 | 04:07 PM
  #33
Aozora's Avatar
Aozora
gee I remember the RATTLER a bunch of pucks inside big holes that dampen the vibration with no elastomer to wear out.
and yes they DO rattle. Curious how well it actually worked!! That design faded away for dampers as far as I know
I'm not sold on the FPC. I know it has some slight advantages, but it's uber costly and brings a whole heard of real issues for that small incremental gain.
FPCs seem to be the new "darling" of the auto exotic world, but I can't help but wonder if they are so wonderful why doesn't NASCAR and other drag race cars that go uber rpms flock to them.
Time will tell if the juice is worth the squeeze.
Conversely, if the advantage is so minuscule why then is the C8R now sporting a flat crank?
Certainly they care more about being fast and reliable for endurance racing than just sounding good?
The magic is staring us right in the face I believe, look to the racing program if you need an example of what GM has in store for us perhaps. It’s not new tech, it’s been being tested under our noses quite vigorously in fact. Plus or minus some MR engine mounts to counter any vibration from such a large displacement FPC motor I think what we see in the racing program will translate to what we see in the production Z06.
“Horsepower sells cars, NA Flat cranks win races.”
-Benjamin Franklin
Old Sep 13, 2021 | 04:40 PM
  #34
Aozora's Avatar
Aozora
It’s settled then! The Z06 is going to be a 5.5L NA FPC V8 making at least 600 ponies. (I’d guess closer to 650) I suppose that means we will see some serious weight saving measures taken as well.
Hows it feel to be wrong all you “TT and 3800 pound” nay-sayers?
Old Sep 13, 2021 | 04:46 PM
  #35
ZRacerLE's Avatar
ZRacerLE
-Benjamin Franklin
Old Sep 13, 2021 | 07:37 PM
  #36
MitchAlsup's Avatar
MitchAlsup
650 from 5.5L is a higher state of tune than the Ferrari 458 engine (2012) !! Not gonna 'appen.
617 from 5.5L is a lesser tune than Ferrari 360 Challenge Stradalé (2005) !! can easily happen.
Old Sep 13, 2021 | 07:39 PM
  #37
MitchAlsup's Avatar
MitchAlsup
Because the gains are not that minimal.
Maintanence costs aside, Ferrari engines are close to bulletproof.
Yes, this is what I think GM is using to quell the vibrations--shock absorbing engine mounts.
To FPC article
Old Sep 13, 2021 | 10:43 PM
  #38
JWP6114's Avatar
JWP6114
"A cross-plane crank will run smoother, but let’s face it. People aren’t building an engine with a flat-plane crank to fulfill a 100,000-mile warranty. If they want the broader power curve and all of the coolness that goes along with it, it is what it is."
THIS... so..... reliability.... can anyone give me a warm and fuzzy feeling? this really didn't. I don't intend to let mine sit any more than it has to. I will daily drive this thing...and I drive a **** load. 100,000 mile throw away? people don't keep super cars much over 10,000 and a Lambo with 30,000 miles or more is considered pretty high miles. as a mechanic i know things will need maintenance... but this part of the article wasn't confidence inspiring. ive seen plenty of C5's and C6's with 120,000+ miles
Old Sep 14, 2021 | 12:42 AM
  #39
Zaro Tundov's Avatar
Zaro Tundov
Any base model DOHC CPC V8 will displace less than 6.2L for efficiency. Ford can exceed LT1 performance with only 5.0L so I wouldn’t be surprised by a new DOHC Stingray V8 with even less displacement.
In regard to reliability the LT6 will be a shitshow. It’ll probably suck for daily driving as well with all that vibration. I’m bummed they didn’t go with a 3.9TT FPC V8 for the ZO6 to keep vibes reasonable, but I suppose with twin turbos GM reliability would be even worse.
GM’s record with bespoke engines is…not good.
Old Sep 14, 2021 | 05:38 PM
  #40
MitchAlsup's Avatar
MitchAlsup
There are lots of Ferraris that make well over 100K miles with nothing more than std factory maintenance.
These are not the ones the owner gets in once a month and redlines it from garage to garage through every gear.
Driven in an adult manner, Ferrari engines are nearly bulletproof.
It is the ones that sit around for weeks at a time that have more problems than the ones driven every day.
These are not the ones that get listed "for sale" because the owner still wants to drive it.
