C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Re-Alignment Required?
Old Jul 4, 2021 | 06:22 PM
KentCNC's Avatar
KentCNC
Default Re-Alignment Required?
I believe many of the custom wheel options move the tire outward some. If the offset is changed, will that require a re-alignment?
I also imagine moving the wheel outward will increase the potential for rock chips on the sides of the vehicle.
Edit: Sorry..meant to post this in the general section.
Old Jul 5, 2021 | 11:44 AM
Glenmcp's Avatar
Glenmcp
I would always realign after putting on new wheels.
Old Jul 5, 2021 | 08:56 PM
MitchAlsup's Avatar
MitchAlsup
Just moving the contact patch on the road surface outward does not actually change the numbers an alignment machine would read. {wheels, spacers,...}
But to get the most tire life out of a new set of tires, the alignment should be checked and set so each number read by the machine is in the center of the alignment tolerance.
To Re-Alignment Required?
