C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Customer C8 Z06 engine issue
Old Dec 25, 2022 | 01:14 AM
  #41
Missileer's Avatar
Missileer
Originally Posted by LukeyW
I wonder how many miles were on the OD when he first went to the dealership. Would a dealer ever pull something like the parking garage scene in Ferris Bueller's Day Off?
Wholly impossible
Old Dec 25, 2022 | 02:31 AM
  #42
Seannyc's Avatar
Seannyc
Someone did damage in the first 3 miles Probley driving hard over the rev limit befor the first 500miles I’m guessing lol
Old Dec 25, 2022 | 03:28 AM
  #43
Jaxian's Avatar
Jaxian
I wonder how much of that 50 miles the engine was pegged to the rev limiter...
Old Dec 25, 2022 | 05:02 AM
  #44
d16dcoe45's Avatar
d16dcoe45
Originally Posted by Vetter_Master
Ouch. This was very sad to watch. Blue smoke and rod knock means that engine spun a bearing and already bent a rod. Unfortunately, it's one thing to claim to mass produce a FPC 5.5 liter 8600 rpm engine, it's a completely different thing to actually do it. We have been singing this car's praises before putting it through its paces. The tolerances in a high compression engine like this is so low that slightest build error or supplier issue with parts and you have these types of failures. Ford has paid a dear price for trying to do the same.
On a side note, when people compare Corvette to Mclaren or Porsche or Lambo and say it's the same car at a fraction of the cost they miss that when it comes to comparing car A to B one must also compare things like OnStar experience as well as dealership not accepting the car when they are closed. This whole experience would have been completely different if this was a failed Aventedor or a GT3. You do get what you pay for.
Hopefully some people come back to reality and drive down these insanely high ADMs for such a hyped up car. Some of these problems are good for the greater buyer market as it will balance some of the insanity.
"Blue smoke means it spun a bearing and bent a rod" 🤦🏻‍♂️🤣
Really? Three completely unrelated events and yet somehow you've deduced just from listening that both of these things happened, A truly "spun" bearing makes a terrible racket because the crank journals are now hitting the ID of the main bore or the big end of the rod. Spun bearing means LITERALLY that: the bearing has grabbed the journal and literally "spun" in its housing. Most of the time that doesn't happen. A bent rod is a completely different event and only happens from overloading the engine at low rpm (excess boost at say 2500 rpm) or something in the chamber that prevents the piston/rod assembly from completing its rotation--there by bending or even breaking the rod.
Blue smoke is from a compromised oil ring and/or valve guide issue. It can happen from a cracked piston from physical contact (valve float which caused piston/valve contact) A pinched ring land from too many detonation events and/or overheating which prevents the second compression ring (which functions as an oul SCRAPER) from doing its job, or pre-ignition which is different than detonation and often FAR MORE destructive.
My point was that the 3 issues you mentioned do not necessarily go together. It could be a number of events happened or one event snowballed causing others.
GM took a big risk in making a 5.5 l FPC STREET car. No one has ever made an FPC V8 that large in a warrantied street car (Ford tried to stretch it to 5.2 litres in GT350 and that wound up being a disaster) The engine basically functions as (2) 2.75 liter 4 cylinder engines and every 4 cylinder I can remember that was over 2.3 liters, had balance shafts, otherwise they would shake themselves to death. It looks like GM mitigated most of the in cabin vibration by installing very soft engine mounts (you can see the engine/trans unit severely tilting on its axis in the Throttle House Z06 videos.
Regardless, people are SO QUICK to jump on the negative band wagon as soon as you get one report of a possible problem. My thought was a possible balance issue creating harmonics which is playing havoc with havoc the valve train at high rpm? Perhaps some of the engines are close to perfect and some are slightly off, and all that inertia at 8500 rpm creates a resonance which is floating valves a lot earlier than intended.
Old Dec 25, 2022 | 08:06 AM
  #45
JVi's Avatar
JVi
Originally Posted by ATC399
Chevy should put about 100 miles on this Beast before it leaves the factory for quality control purposes
Bozos are all you can expect for testing the C8.
https://www.freep.com/story/news/202...ys/4450339002/
They should send them over to a local Toyota factory for QC.
Old Dec 25, 2022 | 08:13 AM
  #46
449er's Avatar
449er
CF Community Team
Originally Posted by LPEC8
How mad would you be if you were that guy, paid 100K in ADM to get a car early and then had to wait 6 months for a new engine? Even worse it looks like it had the **** scratched outta the wheels the way they strapped it down on the tow truck. And it's black so after it spends god knows how long sitting outside BFE Chevy, being leaned into, worked on, bird bombed and walked past his paint should be just about hammered ****. Then once it's fixed every lot rat gets to take a turn behind the wheel for 'drivability testing'. That guy is living my greatest nightmare.
Geez, this guy is definitely a "glass half empty" type of person
Old Dec 25, 2022 | 09:21 AM
  #47
Doctor Mark's Avatar
Doctor Mark
Several thoughts:
1. Break in protocol is there for a reason. Follow it.
2. Abusing any mechanical object beyond its designed capabilities often leads to failure.
3. While having a warranty is great, do you want your car sitting at a dealership for an extended time period and likely coming out with a variety of cosmetic issues that were not there before?
4. It is unrealistic to think that a mass-produced car will be extensively road tested before delivery. Cost prohibitive.
Old Dec 25, 2022 | 09:41 AM
  #48
JABCAT's Avatar
JABCAT
Originally Posted by Doctor Mark
Several thoughts:
And these points illustrate the potential that GM denies the warranty. The first thing they're going to do is claim abuse and not following the outlined break in procedure. I've been through it with GM, the owner may have quite the fight on his hands.
Old Dec 25, 2022 | 09:44 AM
  #49
combatninja's Avatar
combatninja
Pretty sure the cars are actually rev-limited prior to the break-in mileage. My '23 Stingray had a 4K hard rev limit.
Old Dec 25, 2022 | 09:51 AM
  #50
JABCAT's Avatar
JABCAT
They're not actually limited, just visually it makes it appear so.
Old Dec 25, 2022 | 10:51 AM
  #51
Vetter_Master's Avatar
Vetter_Master
I dont think the owner revved the car and even if he did, the engine should not really detonate like this.
Old Dec 25, 2022 | 11:00 AM
  #52
Glenmcp's Avatar
Glenmcp
Well, by my count we now have 4 documented issues with Z06s. 3 transmission failures and 1 engine failure in some 200 odd deliveries. That gives you roughly 2% failure rate at such an early time frame (cars are very new). I'd say we need to give it till June to really see how well/bad this car is. GT350 failures didn't really show their true color until after 6 months.
No need to be one of the first thousand or so.
Old Dec 25, 2022 | 12:34 PM
  #53
undecided1965's Avatar
undecided1965
Default 2023 C8 SR still has DCT issues
Originally Posted by SharkDiverZ06
And this is why I got in line for a 2nd year model car vs. a 1st year.
3rd year in (or is it 4th?)
Old Dec 25, 2022 | 12:57 PM
  #54
Doctor Mark
Not a new concept. Ferrari has been doing it for at least 60 plus years. It is a gradual process not straight to maximum revs. Better to detect an issue before installation in the car. Ferrari also uses it to document that the requisite power numbers are made by the engine.
Old Dec 25, 2022 | 01:03 PM
  #55
Higgs Boson's Avatar
Higgs Boson
In gear, yes, but park/neutral has a soft limiter to prevent free revving.
Old Dec 25, 2022 | 01:26 PM
  #56
mfain's Avatar
mfain
I'm going to take a couple of minutes to defend the OP. He will probably be our only link to finding out what happened to this motor, and he reached out to the forum early. Once GM gets hold of the car, we probably won't hear much. I actually watched his whole video, and unlike the keyboard warriors who formed their condescending opinions based on a few seconds of uninformed viewing, there was a lot of good information. First, it is pretty obvious that the motor has problems - harsh mechanical sound and probably oil in a combustion chamber (right bank). The OP seemed genuinely concerned and knew enough about cars to suspect a problem early on. He owns 2 other C-8s, and from the video views of one of them, his comments about the car, and even the way he parks them in the video, he takes excellent care of his vehicles. He even had a dealership salesman following him when he first heard the "ticking". My concern would be how a dealer stock car was treated before he drove it off. I believe he commented the car had 3 miles on it when he picked up, but my concerns are the idiots that have access to the car before the sale and who want to rev a cold motor to show off the unique sound. Revving a cold, new motor with no load on it is a very bad idea. You see that happen all the time on YouTube videos. When I picked up my first C6 Z06 in 2016 (I was at the dealer for the unload), there was another new, undelivered customer car with a broken valve spring - employee revving a cold engine hard and developed a ticking sound. i am hoping this is an isolated component material failure (or cold, no-miles motor abuse) and not something we are going to have to deal with on a larger scale. I went through the era of the early C6 Z06 broken valve springs, spitting needle bearings from the rocker arms, and eventually dropped valves due to improperly machined heads. Luckily I was not impacted. I am not totally risk averse, but I just want the facts from credible sources so I can weigh risk versus reward regarding a purchase.
Old Dec 25, 2022 | 03:04 PM
  #57
Missileer's Avatar
Missileer
8.5mpg over 50 miles tells me the engine was not handled gently
To Customer C8 Z06 engine issue
Old Dec 25, 2022 | 03:10 PM
  #58
MDawg's Avatar
MDawg
"and developed a ticking sound"
A little bit of tick is normal right? Now I'm paranoid about Z06. It definitely has a tiny bit of a ticking sound, but I'm pretty sure I have heard a similar noise from my Cadillac.
Old Dec 25, 2022 | 03:27 PM
  #59
mfain's Avatar
mfain
Listen to the change in sound at 10:30 on the video. I am afraid that is a little bit more than a ticking sound. Sounds valve train to me, but I'm not there or qualified to offer an authoritative opinion without proper diagnosis.
Missileer quote: 8.5mpg over 50 miles tells me the engine was not handled gently
The 18.7 mph average speed might also indicate a lot of idle time driving the mpg average down and not really that much abuse in those 50 miles.
Old Dec 25, 2022 | 04:04 PM
  #60
Missileer's Avatar
Missileer
Not really..But ok
Plenty if other inconsistencies in the story
