C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
LT6 engine failures/problems
Old Feb 3, 2026 | 08:37 AM
  #601
chevyrules727's Avatar
chevyrules727
2024 C8 of the Year Winner - Unmodified
Originally Posted by TORQUENDB
And it seems my issues aren't over even after my engine replacement. Driven a little over 400 miles on the new engine and it started to sound a little off and feel sluggish. Engine note became less singing and more growling, no MIL or vibrations. When I get home, I decide to check the oil level, which I had not yet done since the replacement (yes, I know, should have checked at the dealer before I drove off. Hindsight 20/20, etc.). Following the procedure in the manual (coolant temp at 175F, engine idling), I just about had a heart attack. According to the dip stick, the oil level is a foot or more above the full mark. There was oil all the way to just a couple inches below the cap. I wiped the stick and rechecked about 3 more times, just to make sure I wasn't going crazy, and it was the same extremely high reading each time. And after letting the car cool and sit overnight, I checked without starting the car to confirm my suspicions: the oil level reads at the normal level, when off...
I'm furious right now, the car has gone through most of its break-in period with what must be almost double the correct amount of oil. I have no idea what possible wear or damage has been done. My dealer will be hearing from me later this morning, and I am not going to let them off the hook for this. All of my care following the engine break-in to the letter ruined by their complete incompetence.
Is there any chance that the engine has not been damaged or prematurely worn? I never saw smoke during the time I drove it, but something was definitely not right the last ~15 miles.
Surprised it wasn't smoking if it was that drastically overfilled.
But if it was that drastically overfilled, oil likely got into the vent line in the tank that goes to the intake. Oil may be all over the intake and maybe valves.
Old Feb 3, 2026 | 08:44 AM
  #602
TORQUENDB's Avatar
TORQUENDB
Could it have gotten oil on the MAF sensor and caused the ECU to pull timing?
Old Feb 3, 2026 | 08:48 AM
  #603
chevyrules727
That I don’t know. Not sure where the MAF is and where the oil tank vent line dumps into.
But oil could be causing air flow issues depending on how bad it sprayed everywhere…..
Old Feb 15, 2026 | 06:19 PM
  #604
James Walt's Avatar
James Walt
I am here. I have been messed up since the soy bi products attracted rats in my car and cause havoc on the washer fluid bottle, wiring for PDR. air ducts and now my Service advisor say the harness for the body control has had some damage. now if GM is using this soy product in the vehicles it should be known so customers can take precautions measure to keep, they butt out of a 110k car. I see that Honda and Toyota has lawsuits in, on that same problem. now i have 7000 dollars worth of damage to my car WTH!!!
Old Mar 12, 2026 | 11:31 AM
  #605
cajunboyz's Avatar
cajunboyz
From: South Lousiana (Cajun Boys with Bad ASS Toys)
This IS F....d Up
Old Mar 24, 2026 | 10:17 AM
  #606
JoelVetteguy's Avatar
JoelVetteguy
Just a thought.
As a prior owner of Gen 1 and Gen 2 GT350 FPC's that both never had any issues and didn't use a drop of oil. The 350 like the Z06 it has huge oil coolers. When I lived in a cooler climate driving at anything less than 60 degrees the engine oil took forever to get to operating temp. Sometimes driving to work 15 miles didn't come close. So I NEVER ran the RPM's above 3K. As we know these FPC engines spin up quick and put a ton of stress on the engine when cold. Not saying those with LT6 engine issues didn't watch the oil temp prior to running high rpm's. Or that's the reason for issues,
Just getting my Z06 a few weeks ago yesterday took her out for a spin. I noticed my oil temps took quite a while to rise to normal and it was 75 out.
Old May 3, 2026 | 06:46 PM
  #607
Kingvetgt3rs's Avatar
Kingvetgt3rs
New Member
Default GT350 of 2026
They are most likely going to come up with .2 for the engine; if you remember, GT350s were breaking down left and right due to it being a flat V8, and if you push your memory far back, 458's had the same issues; they would go up in flames. These are race engines, they don't last that long, that's why Ferrari left V8s and and v12s are cross. But yeah, no solution.
Well, at least we know they copied 458 well lol... and I have heard they are going to copy McLaren for C9
Old May 4, 2026 | 07:53 PM
  #608
ljason8eg's Avatar
ljason8eg
Are you saying Z06s are breaking down left and right due to engine failures? What evidence do you have?
Old May 5, 2026 | 09:14 PM
  #609
Sharkbite 6870's Avatar
Sharkbite 6870
I just finished my break in period today, it was so tough keeping it under 4k rpm!!!
The tach redline changed while I was driving about a half mile after I hit 500, I found the space/time to nail it to redline through at least 2-3 gears about 10 times after and it was spectacular!!! No problems here at all it's insanely awesome!
Old May 6, 2026 | 05:38 AM
  #610
VinnyP's Avatar
VinnyP
Thats what I like to hear.
