C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Can we analyze (w/ sound) normal engine noise vs “the tick”
Old Sep 29, 2024 | 04:46 PM
Misty C8 Z06's Avatar
Misty C8 Z06
Default POST TSB Update
Originally Posted by Misty C8 Z06
its left side so engine stays in cradle; right side requires engine removal.
just got the 24 z back from my dealer who has been great to work with. The tech did the tsb and comparing videos of the tick before and after, there isnt much, if any, difference. The left side is still noisy vs the sewing machine typical noise on the right side. The pico scope showed noise like the tab identified pre the tab attempted repair. Going to ask the dealer to put pico scope back on and send results to gm and see if there is another action to take or just hold.
Old Oct 8, 2024 | 08:48 PM
Misty C8 Z06
dealer did pico scope after performing tsb because left side was ticking. Dealer sent results to GM who said do the TSB again. Hope they can fix second attempt.
Old Oct 8, 2024 | 08:54 PM
Mitchell_B's Avatar
Mitchell_B
At this point I would request your dealer send a field engineer to perform this procedure with the local tech. Argue your case - this is the second time/attempt and you want someone from GM engineering present. The dealership has to make the request.
Old Oct 8, 2024 | 09:18 PM
Misty C8 Z06
good call. Will request one.
Old Oct 13, 2024 | 09:23 PM
Cliff1620's Avatar
Cliff1620
Veteran: Marine Corps
Mine sounds the same and I just got my Z 2 weeks ago.....
