To the other man, I did scroll down. I don't see any mention of a 2024 Z07 with the carbon fiber wheels.
Y'all take care,
Robert
FYI the lug nuts are the same size as non carbon fiber wheels and take a 22 mm socket as Kracka said, the studs are longer to reach through the thicker cf wheel hubs. To use non cf wheels without changing the studs requires an open end lug nut.
Also, is 140 ft/lb the correct torque for the carbon fiber wheels?
Thanks,
Robert
What about the 140 on the torque question? I have the exposed CF wheels and was wondering the same.
Manual says 140 ft/lb without specifying wheel type. 140 seems fine for the aluminum rims, but feels high for CF.
But what do I know because never owned a car with CF wheels before.
Yes the 140 foot pounds is torque spec for CF wheels as well!
Probably will never apply to you in Texas, but CF wheels are affected by temperatures too.
Was unaware of that. We do get freezing temps here occasionally. Several years ago we had a string of freezes, one of which lasted for several days and busted pipes, including a couple of mine in the attic. Fortunately my leaks were minor and I was able to shut off the water before my LPs were ruined. Many others were not so fortunate.
Note that every sock, including the various non-marring ones referenced above, will have metal to metal contact on the lug nut surfaces. The plastic will protect the tip of the lug nut, and the inside of the hole in the wheel. But if you're trying to prevent marring to the hex surfaces, there's nothing available. I'm not aware of any plastic sockets designed for 140 ft lbs of torque.
