C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Oil temperature
Old Feb 19, 2025 | 05:04 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I think the confusion arises due to the fact that the LT6 reports the temperature for the oil in the tank NOT the temp coming out of the engine, which is plenty hot. That's a change from the way temps were previously reported. For tracking, the important oil temp is the temp of oil going into the engine, not the temp exiting the engine.
Old Feb 19, 2025 | 06:46 AM
chevyrules727's Avatar
chevyrules727
2024 C8 of the Year Winner - Unmodified
Originally Posted by sd05gt
wow good to know. Definitely going to drive it a bit after washes thanks for the heads up… 👍
Surprised it wasn’t an issue with the GT350. Fairly common with performance brakes.
Old Feb 19, 2025 | 09:57 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
What a sweet ride you go there! If you're unable to find an answer here, your local Chevrolet dealership is staffed with professionals who will be able to provide a more precise answer. For help locating one near you, feel free to email socialmedia@gm.com.
Old Feb 19, 2025 | 10:23 AM
subydude's Avatar
subydude
This piece combined with the fact the engine has a dry sump pulling some vacuum on the crank case which lowers the boiling point of water by a good bit. GM states it can hit 80 kPa at high rpm or around 11 psi of vacuum. While it's certainly less at cruising rpm, there would still be some vacuum in the crank case. If you use the redline pressure in the engine of roughly 4 psi absolute that puts waters boiling temp just above 150 degrees F. So once you take into account the oil is measured in the tank, the vacuum in the crank case, etc, it's pretty easy to see all the old school stuff can be thrown out the window and just drive the car.
Old Feb 26, 2025 | 08:48 PM
Mitchell_B's Avatar
Mitchell_B
For clarification and understanding, engine oil is pulled from the tank to the pump, then pushed through the oil cooler, then the oil filter where it exits the filter and enters the main oil gallery in the block. The oil temp sensor (21) is positioned in the oil filter housing and measures oil temp as it exits the filter before entering the main oil gallery.
The oil cooler is an oil to water heat exchanger. A portion of the return coolant flow from the front radiators is split off to the auxiliary radiator inside the duct just forward of the driver's side wheel. This coolant is further cooled and then delivered to the engine oil cooler. This coolant then exits the oil cooler and combines with the main return coolant flow from the front radiators.
