C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
High flow cat options?
Old Dec 26, 2025 | 06:34 PM
FORZAMOTORWORKS's Avatar
FORZAMOTORWORKS
Supporting Vendor
Originally Posted by JrBucks
Are you AWE from back in the VW/Audi 1.8T days? Do you do installs? I'm local.
I’m AWE’s preferred local installer (Warminster) but we’re two separate companies. But yes, AWE got their start with VW/Audi
Give me a shout, happy to help
- Alec
267.788.4897
__________________
Alec @ Forza Motor Works
(267) 788.4897 Call/Text
info@forzamotorworks.com
www.forzamotorworks.com
Your trusted source for premium parts - offering competitive pricing, exceptional service, and professional installation options.
Corsa | Borla | AWE Tuning | Girodisc | Halltech | American Racing Headers | Milltek | Soler | Weld | Fabspeed | SOUL | Kooks | BC Forged & 100's more!
Old Dec 26, 2025 | 06:42 PM
JrBucks's Avatar
JrBucks
- Alec
267.788.4897
AWE built some wicked stuff. I'm right up the road in Ottsville. Can you PM me the install price for the the High Flows when you get a chance? I know what you're asking for the Millteks.
Old Dec 27, 2025 | 12:45 PM
Gang Green's Avatar
Gang Green
Definitely the HF Cats - happy to help with either
- Alec
267.788.4897
Thanks - Starting to hear a lot of noise regarding Milltek Cats & CEL's - Especially after the last software update. Any insight to this?
Old Dec 27, 2025 | 02:25 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
Originally Posted by Gang Green
Question - Which set up sounds louder more aggressive?
Milltek High flow cats or AWE Cat Back Exhaust?
Cats, the OEM exhaust is pretty gnarly as is.
-Josh
Old Dec 27, 2025 | 05:49 PM
JrBucks's Avatar
JrBucks
Question, and I apologize if this has been discussed prior. Does adding the Hi-flow cats void the warranty?
Old Dec 27, 2025 | 05:55 PM
Cobo_pro's Avatar
Cobo_pro
Real world answer is that it depends on the dealer doing warranty work.
Theoretically, GM would need to identify the modification as a causal factor for the associated breakdown. Some draw a harder line, and some are not so stringent.
I have had warranty work done on a hellcat that was straight pipe, on e85, pulleyed down and even on an Evo that had upgraded 3076 turbo, tuned, Shephard transmission, etc.
I have never had a warranty claim rejected by any manufacturer, but have heard horror stories of those who have.
I modify under the assumption that is something were to break in the area (1 level up and 1 level down from modification point), then i am prepared to pay for the repair (lilely aftermarket upgrade).
The only deviation from this would be tuning of the ECU, which i understand not to be currently possible for our platform, but could potentially void any and everything powertrain and certain things electrical
Old Dec 28, 2025 | 01:51 PM
MerakiAutoworks
Supporting Vendor
No it should not, unless you have an engine problem they can blame the cats then.
-Josh
Old Dec 28, 2025 | 05:02 PM
Kitch28's Avatar
Kitch28
This response sounds like if you do have an engine problem you may pay out of pocket
-Josh
Old Dec 28, 2025 | 05:18 PM
JrBucks's Avatar
JrBucks
I would imagine if a cat melted down and the motor popped, you're on the hook. That would be highly unlikely on the factory tune unless someone added FI or was playing with NOS, or using a fuel that isn't CC friendly. But it is possible and a consideration.
Old Dec 29, 2025 | 04:11 PM
Gang Green's Avatar
Gang Green
Any insight to the reported increase of CEL's with the Milltek HFC's? Seems to have increased since the recent software update? Any truth or concerns about this?
Old Dec 31, 2025 | 08:12 PM
Malfred's Avatar
Malfred
I replied earlier in the thread saying I have Milltek high flow cats and no CEL. That reply was clearly a jinx, I popped a check engine light today. Scanned using my reader and had no code but the light was on, so maybe a prelim not a hard code but not sure. The light came on during a warm start with about 35 degree Fahrenheit ambient air temps. I’ve had the cats on about 125-150 miles. I don’t know my current software version.
Old Jan 1, 2026 | 08:59 AM
fusiongt's Avatar
fusiongt
OEM cat is rated at 700 cell and any aftermarket high flow cat rated at 200 cell will throw code eventually. Just don't buy into these "no CEL" promises from vendors. 02 Spacers is your best friend.
Old Jan 3, 2026 | 10:31 AM
  #33
Gang Green's Avatar
Gang Green
@Malfred Thanks for sharing - Were you able to clear the CEL and if so, did it pop back on again? I would hate having to deal with that...
Cat back exhaust better in terms of CEL possibilities?
Old Jan 3, 2026 | 11:51 AM
  #34
PhoenixM3's Avatar
PhoenixM3
If an aftermarket cat’s substrate breaks down, there is a chance that pieces of it could be ingested during a high rpm downshift. For this reason AND I dont want to pay $3k+ for high flow cats, I want to install catless test pipes. Who sells ‘em?
Old Jan 3, 2026 | 12:53 PM
  #35
95vettski's Avatar
95vettski
Check out this video by Paragon Performance discussing the Milltek cats.
The o2 sensor bung/angle is very sensitive and can trigger a cel. Milltek made a revision after the original design to accommodate the Eventuri (which still wasn't compatible) and customers are reporting a cel. Milltek will now continue to sell the original version which seems to be working without any issues.
I have been using the the original v1 design with the oem airbox and have never had any cel logging over 4K miles.
https://youtu.be/TbYuStRjb8M?si=2SGQ4KOfILIQ5EFt
Old Jan 3, 2026 | 01:00 PM
  #36
fusiongt's Avatar
fusiongt
Just install 02 spacer and yes, your 02 sensor will trigger cel for going from 700 cell to 200 cell.
Old Jan 3, 2026 | 02:23 PM
  #37
AussieTrackrat's Avatar
AussieTrackrat
Just get an OBD2 dongle and reset the CEL periodically. It comes on every 2-3k.
To High flow cat options?
Old Jan 3, 2026 | 02:56 PM
  #38
fusiongt's Avatar
fusiongt
Even if u clear the cell, dealer can still see the ecm log and trust me, when u have to make any engine related warrenty claim, dealer will blame u for ignoring(no service records) all these CELs. I got v1 miltek and cel at 2600miles. Got 02 spacers and no cell since.(fingers crossed btw)
Old Jan 6, 2026 | 06:30 PM
  #39
Fast Boat Guy's Avatar
Fast Boat Guy
Default CEL update?
Any updates/fix for the increase in CEL with Milltek HFC since the new GM update to the cars?
I was told last week that there has been a GM over the air update, that now recognizes hi flow cats. Any truth to this? Any fixes?
I was planning on ordering some, but trying to avoid the CEL if I can.
Any insight will be appreciated
Old Jan 7, 2026 | 07:31 AM
  #40
fusiongt's Avatar
fusiongt
You gotta pay to play. Want your car louder? just deal with CEL. Don't want no headache? Leave the car as is. It's your call.
