2023 Z06 Front Plate Mount
I did the Sto n Sho also. If people don’t want to run a plate, this is a great option. You can keep it mounted in the frunk, so if you do get pulled over, you can just say you forgot to put it back on after doing whatever.
A front license plate just destroys the look of a car, especially sports car. Saw a Cayman GTS 4.0 yesterday with a front plate and it was awfull.
Easy to spot the CA refugees when they first get to FL by their ugly front plates.
I finally decide that at some point I was eventually going to get pulled over by a statie having a bad day. I bought this one, installed it yesterday and it is very slick. Tracked today, 2 seconds off or on mounting bracket uses existing splitter mounting points and they make one for cars w/o splitters.
https://stonsho.com/products/front-l...litter-sns200c
You can't fight city hall
It is what it is
Received 11,810 Likes
Here's what I did without using that ugly paint rubbing factory mount.
https://www.corvetteforum.com/forums...nse-plate.html
