Break in period - 1500 mile road trip - yay or nay?
It has been a couple of years since release, lots of deliveries, lots of different experiences.
What say you about embarking on a ~1500 mile road trip immediately after taking delivery of the car? Gentle driving, frequent gear/RPM changes, steady vehicle speed for protracted periods.
Acceptable? Or unforgivable breach of break in protocol?
JustnRiptide (03-23-2024)
Sounds like a perfect way to break it in, I say go for it!
The following 4 users liked this post by minn19:
I would recommend Paint Protection Film and the front radiator grill guards before you go on the trip. I did a 2,000 mile road trip with other Corvettes shortly after taking delivery. I had PPF which protected the paint, but the front radiators got dinged up pretty bad.
The following 2 users liked this post by CliffB-99:
JustnRiptide (03-23-2024),
nolimits (03-23-2024)
AustinVetter (03-23-2024)
The following 2 users liked this post by fjaphd:
Kracka (03-23-2024)
Keep in mind that what you are doing besides miles and rpm is heat cycles. Gradually allow it to get hotter and hotter between cool down.
I would say vary the speed a bit, and you should be good to go. With my first C8 I drove it from Northern to Southern California. I ran it in different gears and speeds. You want to run the rear axle at different speeds, too, not just the engine, and give it some gentle acceleration and deceleration cycles. It broke in perfectly.
Received 2,375 Likes
C4 of Year Winner (performance mods) 2019
Road trips are a perfect way to break in the car as long as you follow the procedure. I did this on my z after taking delivery from the museum and driving it back to Texas. Put nearly 1000 miles on it in 2 days and following the procedures to a T. I have 3000 miles on it now and she's been perfect!
Me and my buddy took about an hour to put on track wrap at the museum after delivery. It worked great and was easy to take off when I got home 1000 miles later. Not a scratch or nick anywhere. Have fun with it!
Buy track wrap roll on Amazon, use it to protect key areas and go
this:
https://a.co/d/bZIxFg3
I brought mine home from MM and racked up 500 miles easily. I did the first half on backroads which naturally forced me to vary the speed and rpms. Stop for coffee. Stop for lunch. The last part of the journey was highway and I would vary the speed and do frequent downshifts to run the rpms across the full range. I also made a couple stops at rest stations. After passing 500 miles the tach changes and I let her rip.
Sounds encouraging.
It was never clear from the GM videos if vehicle speed variation was relevant, or just engine speed.
New engine, new tech, high power, reports of issues - I want to maximize the chances of worry-free long-term ownership.
