Official : The ZR1 is coming this summer
#261
Pro Mechanic
Pro Mechanic
Yeah. I'm sure @Hib Halverson will be happy to confirm or correct me, but I believe the ZR-1 had some of the softest springs of the entire C4 line-up. If not in the rear, definitely in the front.
The rates are in newtons/millimeters. Dimensions are in millimeters except for wheel dia. and width which are in inches.
The column headings ft. spring rate | rear spring rate | front wheel rate | rear wheel rate | front bar dia. | rear bar dia. | front wheel size | rear wheel size | front tire | rear tire | codes
S-Solid antiroll bar
T-Tubular antiroll bar
1-Delco shock
2-Delco shock, convertible specific
3-Delco/Bilstein gas shock
4-Delco/Bilstein gas shock, Z51 specific
5-Ride-adaptive Delco/Bilstein gas shock
6-Delco/Bilstein gas shock, convertible specific
7-Delphi bi-state ride adaptive gas shock
8-Delphi bi-state ride adaptive gas shock, convertible-specific
9-Delco/Bilstein gas shock with valving revised for improved ride
10-Delco/Bilstein gas shock with valving revised for improved ride, Z51- specific
N-Normal, front, lower control arm bushings (ft. 11k n/mm, rr 2.3k n/mm)
HD-Heavy-duty, front, lower control arm bushings (ft 13.5k n/mm, rr 3.5k n/mm)
E-EMT tire available
So...C4 ZR1s had low spring and wheel rates compared to C4s with RPO Z51 or Z07, and that was especially true at the rear because the rear spring rate is what you feel in your butt. Soft asses of the gold chains types who bought most of the ZR1s drove the customer input that had GM put very soft rear prings in C4 ZR1s.
That said...folks interested in better handling would fit C4 ZR1s with higher rates springs, higher rate stabilizers appropriate for autoX or tracking along with other suspension mods, however, even with mods, C4 ZR1s could not violate the laws of physics. The heavy LT5 engine was a hindrance if the competition was a C4 Z51 with a Small Block V8 juiced-up with some aftermarket pieces or maybe a transplanted '96 LT4 fitted with the GM "Hot Cam" and headers.
#262
Figured I'd add to the tsunami of speculation about ZR1 and "Zora" with my wild-assed guesses.
ZR1: LT7 engine–the twin-turbo version of the LT6 at about 800-hp. Rear drive only. Not track-focused as is the Z06. More of a GT car so it will be available in a pretty luxurious form.
Is your knowledge of the C4 ZR1's history what makes you speculate that the C8 ZR1 will not be as track focused? With the big wing (option) the rear spring rates will need to be significantly higher to handle the downforce at high speed. In your opinion, is it likely that there will be a "performance option" that gives better spring/shock rates and suspension calibration for track use at the expense of a soft ride? Thanks
#263
Received 3,891 Likes
"Ask Tadge" Producer
Hib,
PRE-Z06 (04-15-2024)
#264
Received 2,079 Likes
#266
The '90 ZR-1 was pretty harsh, my '95 ZR-1 was way too soft (floaty) in tour mode.
robob (04-16-2024)
#267
#268
For the privileged.
Good luck and enjoy safely.
#269
Received 4,391 Likes
#270
#272
This summer that's great news, so will it be available at the dealers later this year? or next year?
#273
Children. Please go somewhere else to whine at one another.
kevinprimetime (04-26-2024)
#274
#275
Interesting all those who find a TT option as unthinkable... GM already had the blackwing, which I remember wild speculation it would be introduced to Camaros and Corvettes. Pacing the competition and given GMs shift with the C8 the ZR1 will undoubtedly be turbo'd ... The question is if they have some hidden tricks with batteries, AWD , active aero among other things found with Porsche, McLaren etc ...
LukeyW (04-24-2024)
#276
PRE-Z06 (04-24-2024)
#277
Received 5,349 Likes
From the Bash... engineer saying the LT7 will not be FPC.
#279
#280
Very interesting... CPC w/ AFM followers. Any word on the LT6 getting AFM then?
